    Ultimate Dual Fan for Pi3
    pi coolingcooling fancooling
    52 Posts 12 Posters 15.1k Views
    • spruce_m00seS
      spruce_m00se
      it will probably sound like you have a swarm of angry mosquitos inside your case aswell :)
      DD-IndeedD 1 Reply Last reply Reply Quote 0
      • DD-IndeedD
        DD-Indeed @spruce_m00se
        @spruce_m00se
        That's also something I'm afraid. But, I can always use the 3.3V line instead of that 5V, to make them run a bit more quieter.
        My soul rests, when I hear the PS1 boot music
        spruce_m00seS 2 Replies Last reply Reply Quote 0
        • spruce_m00seS
          spruce_m00se @DD-Indeed
          @dd-indeed a bit, I tried that with one, and it drove me MAD!
          • spruce_m00seS
            @dd-indeed I actually bought a cheapo android based KODI box because the PI got so hot running KODI and the fan was annoying me too much, so 30 USD for a kodi box and it seems more responsive anyway and has an IR remote, so happy days, stuck it on a laptop cooling pad and its all gravy
            • DD-IndeedD
              DD-Indeed
              Now I actually ran into pretty foolish trouble: I can't find a single benchmark test, that could be used via command line of the Retropie. Only ones I've found require OS to boot.
              Edit: Nevermind, found one simple Linux test to be used with this.
              • DD-IndeedD
                DD-Indeed
                Raspberry Pi 3 - Ultimate Dual Fan-cooler Tests
                Overclock settings:
                arm_freq=1300
                gpu_freq=525
                core_freq=250
                sdram_freq=500
                over_voltage=4
                v3d_freq=500
                force_turbo=1
                avoid_pwm_pll=1
                disable_splash=1
                Commands used to do CPU tests:
                • vcgencmd measure_temp
                • sysbench --test=cpu --num-threads=8 --cpu-max-prime=50000 run
                I ran the test multiple times until I reached the max temp for each setup.
                Temp results:
                With my original customized chipset cooler with 40 mm 5V fan = around 50 C
                Without cooler = Over 80 C, thermal throttling warning visible
                Ultimate Dual Fan-cooler with included thermal adhesive tape = 77 C + thermal throttling
                Ultmate Dual Fan-cooler with copper plates and thermal paste = 70 C, no thermal throttling thou.
                So yea, this device is piece of crap with the thermal tape, absolutely useless. And, when you apply copper plates with thermal paste, the results improve slightly.
                As a ''straight-out-of-the-box-and-bolt-on-device'', it's not good, nowhere near of good, and even with improvements, it's still crap.
                Conclusion: I'm not recommending this at all. Waste of money and time.
                spruce_m00seS 1 Reply Last reply Reply Quote 1
                  PiBoy
                  The dual fan test results are almost identical to what I got when I attached a fan with a heatsink to the CPU. Mine idled around 42 and topped out at 68 (with overclocking). However, I used the adhesive that came with the heatsink, which may have been that 9448 tape stuff, non conductive.
                  I am not convinced the SMC needs to be there, that second fan might not be doing anything.
                  • spruce_m00seS
                    @dd-indeed how do you run this test? I may run it on mine with the big cooler and see what happens
                    • spruce_m00seS
                      spruce_m00se
                      well i just did some heat tests,
                      27.5 ambient
                      51-52 on idle no fan
                      38 idle with fan
                      53 q3 playing with fan
                      67 q3 playing q3 no fan
                      Crashed.
                      from playing q3 with no fan in the past it used to give the temp warning sign after about ten mins, but this time it crashed before it got that far
                      • DD-IndeedD
                        @spruce_m00se
                        And you used stock clock settings for the Raspberry ?
                        Here's the test I tried:
                        (https://askubuntu.com/questions/634513/cpu-benchmarking-utility-for-linux)
                        ''Actually there is a a tool named as sysbench.
                        You can install it with sudo apt-get install sysbench
                        To CPU benchmarking you can do like:
                        sysbench --test=cpu --cpu-max-prime=20000 run
                        where 20000 is like max event count.
                        --cpu-max-prime=20000 is optional, the default being 10000. I suggest to keep the default and fiddle with --max-requests instead (which is the number of operations performed)
                        Also note that by default this is a single-threaded test. For testing N cores you can use --num-threads=N (N = Any number you desire, I used 8 to properly stress the system. -DD), and compare results using the per-request statistics output.''
                        So, I used this command in my tests:
                        And immediately after that, I checked the temps with this command:
                        I'm not expert on Linux commands, so maybe someone could create simple script from these, that could be easily accessed and used for these tests.
                          Translations
                          Just wanted to give my experience with these kits as I just got mine a few weeks ago, I have one of these dual fan kits in a Nespi case with the Pi overclocked to 1.35 and I have yet to get a single temp icon. Before the kit when I was just using heat sinks on the stock clock speed I was consistently getting the temp icon after about 45min of play time, so it does work and it is extremely quiet. Come on guys this thing cost $13 shipped from China, not sure how you can complain?
                            A Former User
                            It’s worked excellent for me. A little loud but other than that it’s really cooled my pi off.
