    XArcade Tank Stick Issues
    xarcadexarcade retropixarcade2jstickfinalburn alphamame 2003
    44 Posts 6 Posters 12.6k Views
    • caver01C
      caver01 @mbrett
      @mbrett You have a period, not a comma in there.
        mbrett @caver01
        @caver01 I moved them to libmame folder. I have Arkanoid working. Need to find different Centipede ROM. I have every Golden Tee working with libmame 2010. But no trackball support. So close...
        • caver01C
          caver01 @mbrett
          @mbrett No need to give up on advancemame. You just need to eliminate the syntax errors in your .rc file. GT roms work great in AdvanceMAME3.x--better even than they did in AdvanceMAME1.4.
          Did you go through this how-to?
            mbrett @caver01
            @caver01 Really odd. I've corrected the advmame-.98.rc. But now Golden Tee '97 says this. And I had it working last night:
            Parameters:
            Executing: /opt/retropie/emulators/advmame-0.94/bin/advmame "gt97"
            AdvanceMAME - Copyright (C) 1999-2003 by Andrea Mazzoleni
            MAME - Copyright (C) 1997-2003 by Nicola Salmoria and the MAME Team
            gt97prm0.130 NOT FOUND
            gt97prm1.130 NOT FOUND
            gt97prm2.130 NOT FOUND
            gt97prm3.130 NOT FOUND
            gt_nr.u88 NOT FOUND
            gt97_grm.0_0 NOT FOUND
            gt97_grm.0_1 NOT FOUND
            gt97_grm.0_2 NOT FOUND
            gt97_grm.0_3 NOT FOUND
            gt97_grm.1_0 NOT FOUND
            gt97_grm.1_1 NOT FOUND
            gt97_grm.1_2 NOT FOUND
            gt97_grm.1_3 NOT FOUND
            gt97_grm.2_0 NOT FOUND
            gt97_grm.2_1 NOT FOUND
            gt97_grm.2_2 NOT FOUND
            gt97_grm.2_3 NOT FOUND
            gt_srom0.nr NOT FOUND
            gt_srom1.nr NOT FOUND
            ERROR: required files are missing, the game cannot be run.
            Is it possible to just get MAME-2010 to see the trackball? The GTs all work perfectly in that, except trackball.
            Also, this advMAME 3. you talk about I can't find anywhere. I appreciate the help, but the bread crumbs are getting frustrating. Yes, I've read everything.
            • caver01C
              caver01 @mbrett
              @mbrett When you install AdvanceMAME you get three versions: 0.94, 1.4, and 3.x (latest). The version 3 is just plain AdvanceMAME. The advmame.rc file is for 3.x. They have left the dot version number off because it has been getting frequent updates. From the emulators.cfg:
              advmame = "/opt/retropie/emulators/advmame/bin/advmame %BASENAME%"
              AdvanceMAME3.x (and 1.4) requires romset 0.106 which is obviously different than the set required for 0.94.
              The error you noted above is MAME thinking you are missing ROM files. I can't explain what you might have changed between then and now.
              Are you using runcommand to pick the different versions?
              As for MAME2010, I don't know if that one has mouse support. I don't use it. MAME2003 is by far the most developed in terms of working features among the libretro cores, and AdvanceMAME3 is the most versatile.
                mbrett @caver01
                @caver01 [Faceplant] Nope. I can't do it. I can't download another ROMset of 60gb just to get six damn ROMs. So ridiculous. Oh well. I guess I'll try to get MAME 2010 to work or just fuck it, and do Golden Tee on PC. So frustrating.
                • caver01C
                  caver01 @mbrett
                  @mbrett Sorry you are frustrated. It is the way MAME has always been, and it is always an important moment when users finally realize this. You'd be surprised how much time is spent trying to troubleshoot and educate people about MAME ROMs who don't read or comprehend the documentation.
                  That said, you might actually try the ROMs you have. It's not a supportable technique, obviously, but while ROMs have changed in step with MAME's development, many have not required updates. You may well have ROMs that will 'accidentally' work with several versions of MAME.
                    mbrett
                    @caver01 Huzzah! I have MAME 2010 working like a champ.
                    /opt/retropie/configs/all/retroarch-core-options.cfg
                    mame_current_mouse_enable = "enabled"
                    Bingo!
                    • caver01C
                      caver01 @mbrett
                      @mbrett How's the performance? 2010 has always been a little sluggish on some things, but maybe on GT it doesn't matter. I might switch over to it. I am using AdvanceMAME for GT roms.
                      If you like vector games, I recommend getting Advmame running. They look much better in Advance than any of the lr-cores.
                        mbrett @caver01
                        @caver01 '97 worked great. That's all I tested. If I didn't have to dl an entire new ROMset, I'd be all over advMAME for vectors. As it is, I don't have that many vector games, so, as the GTs, it would probably not be worth it.
                        • caver01C
                          caver01 @mbrett
                          @mbrett I just tried GT2K in lr-mame2010 and the opening music was stuttering and animation got sluggish. I noticed the Pi was struggling and overheating which is rare for me. Quit and relaunched and selected AdvanceMAME and immediately noticed a difference. Smooth music and no slowdowns or overheat.
                          It might be recent development on Advmame 3 that is making it run better on the Pi. I know it was always a little sluggish, especially with the music on 1.4.
                          Anyway, I thought I would share my results.
                          M A 2 Replies Last reply Reply Quote 0
                            mbrett @caver01
                            @caver01 I just ran GT2K and had the stuttering but no sluggish animation or overheating, and play was smooth to me. To-may-to, to-mah-to.
                            • caver01C
                              caver01 @mbrett
                              @mbrett I did have my arcade system running all day long today while I was at work, then came home and tried this. I guess it was warm already which might be the difference. The animation issues was definitely a result of throttling due to temperature.
                              Nevertheless, as your music was stuttery, I would put AdvanceMAME performance above 2010. Ultimately, playability vs. setup challenge will win out, but know that you have some wiggle room if performance becomes an issue as you heat up.
                                AlCzervik @caver01
                                @caver01 Any chance you could share how you have your GT ROMs setup in the folder(s)? Looking to replicate your efforts with the xArcade tankstick but unsure how to setup the ROMs. Thanks in advance!
                                • caver01C
                                  caver01 @AlCzervik
                                  @alczervik There isn't much to share. I have all of my arcade ROMs in the arcade folder. I use Runcommand to select the emulator. Obviously, choosing different emulators for various ROMs requires that the ROMs themselves come from various romsets appropriate for the emulator choices made. This takes some tracking effort, and for that, I simply use a spreadsheet.
                                    AlCzervik @caver01
                                    @caver01 Thanks for the quick response!
                                      motleypixel
                                      I'm having an issue with my Xarcade Tank stick setup. I too have the Xarcade2Jscript driver installed so the system sees the tankstck as two gamepads. I have the tankstick serial-to-usb plugged into USB 0 (that's the sticks/buttons), trackball plugged into USB 1, wired xbox 360 controller plugged into USB 2 and a wired usb keyboard plugged into USB 3. Configuring the controllers in ES GUI keeps making the Xbox 360 as gamepad/player 1, gamepad/player 2 is the left side of my tankstick and gamepad/player3 (if there is such a player in any of these older games is the right side of my tank stick.
                                      I'm very new to this environment, but have a sound understanding of linux and shell scripting from my regular job. I figure there's a config somewhere that I can just manually vi/edit to fix?
                                      Thank you,
                                      Roy
                                      • caver01C
                                        caver01 @motleypixel
                                        @motleypixel You will probably have to setup hardcoded joystick configurations and focus on RetroArch/libretro core emulators, as these will leverage the RetroArch configs while standalone emulators will each have their own unique configs.
                                        First, take a look at the docs here. You will likely need to pay attention to input_player1_joypad_index setting, and the same setting again for each player. These can be configured per emulator (again, for libretro cores, not stand-alone).
                                        Also, take a look at this thread which you might find useful.
                                        Your configuration is unique enough so that nobody can just give you simple answers. For example, I use a keyboard controller, so I don't have direct examples. You will need to logically work through this, so read the docs and do the tests suggested to find your unique answers and have fun!
                                          jdoc
                                          Hello everyone- I’m new to the Retropie community. My son asked me to read Ready Player 1, and it brought back too many memories of my arcade days- I couldn’t resist buying a Raspberri Pi 3 with Retropie preloaded!
                                          Anyway, I also bought an Xarcade Tank Stick, and after much trial and error (and nuke and pave Retropie installations), I finally got the system working at a decent level.
                                          My setup: RaspPi 3 with Retropie 4.2; Xarcade Tank Stick setup as per these instructions (https://support.xgaming.com/support/solutions/articles/5000554993-how-to-use-x-arcade-with-raspberry-pi); using lr2000 Mame with 0.37b5 ROM’s. I have NOT updated anything except for scripts. Most games work just fine- I’ve been able to find working versions of desired games 90% of the time.
                                          I have a couple of questions: 1. I love Defender. I can load Defender (red version) and play it, but I’d like to reconfigure the Xarcade so the joystick will move the ship up, down, left, right and thrust in both directions. Currently, the stick will only move the ship up and down, and I have to rely on buttons to thrust and change direction. The other buttons (fire, nuke, hyperspace, and hot keys) work just fine. I see that I can configure per individual ROM, but I don’t have a mapping chart to refer to or instructions on how to do it (sorry, I’m a bit of a newbie!)
                                          1. Regarding updating the system: updating anything pretty much destroys the functionality of the Xarcade- this is a known issue I know. Does anyone know a good place where I could track progress on resolving this issue?
                                          And if anyone has recommendations on ROM sets and MAME’s that work well together, I’m all ears!
                                          Thank you in advance for any advice.
                                            jdoc
                                            Also, if anyone has a link to instructions that would allow trackball use for games like centipede and missile command, and instructions for getting the second player controls to work on the Xarcade, that would be great. I assume it’s because I’m using lr2000 and not lr2003, but I can’t seem to find a ROM set that will work well with lr2003.
