    Any Power Switches immune to Under-voltage?
    power supplypower switchundervolt
    1 Posts 1 Posters 750 Views
    • FatWhiteLumpF
      FatWhiteLump
      Does anyone know of a good Power Switch that won't cause any under-voltage warnings? I bought the LoveRPi MicroUSB Push On Off Power Switch Cable for use with CanaKit 5V 2.5A Raspberry Pi 3 Power Supply and my Pi3b but I get under-voltage warnings within 5 minutes of use. I totally disabling my overclock and I still got the warnings. I went back to just using the Canakit power supply and I had no issues .
      Does anyone know of any good external power switches that I can use with the Canakit power supply? Or even a power supply that has a built in switch that can still provide enough power when the Pi is overclocked.
