    Revert to System Bluetooth from Sixad?
    wirelessbluetoothps3
    3 Posts 2 Posters 683 Views
      ckswenson
      Pi Model or other hardware: (3 B)
      Power Supply used: (CanaKit)
      RetroPie Version Used (4.02):
      Built From: (Retropie - Ready .death)
      USB Devices connected: Logitech Unifying
      Hello All, The image I'm running seems like it used sixad to get ps3 controllers working. I've deleted the ps3 driver through the retropie config menu. I've also rebooted and run the systemctl enable bluetooth command. Still, when i run the Bluetooth status I get "not found" and inactive.
      I found lots of threads discussing getting the PS3 running, but nothing about reverting back to the system default bluetooth controller. Wondering if anyone else has overcome this.
      Thanks,
      CK
        ckswenson
        Clarification:
        My symptom is that retropie cannot find any devices when I run the add wizard. I followed the rabbit hole on here about ps3 problems, and it appears that a ps3 driver disabling my system bt driver is likely the cause. I don't have confirmation that is the problem, just my best guess.
        • jonnykeshJ
          jonnykesh @ckswenson
          @ckswenson Third Party images with custom configs and pre-loaded ROMs are not supported here. Go ask Mr .Death for tech support.
