    Help me
    helpemultionstationn64not workingblack screen
    6 Posts 4 Posters 1.1k Views
      Mr.Monkeyface
      My emulationstation n64 is not working it is just a black screen but i can hear the sound. Help
        sonicsheppard
        @Mr-Monkeyface
        Problem with recent update it seems. Couple of other active threads
        https://retropie.org.uk/forum/topic/13269/segmentation-faults-with-mupen64plus-after-update/1
        https://retropie.org.uk/forum/topic/13294/mupen64-black-screen
          Mr.Monkeyface
          I need a download link for Ir-mupen64plus
          • jonnykeshJ
            jonnykesh @Mr.Monkeyface
            @mr-monkeyface It doesn't work like that. Emulators are installed via the Setup Script. However I think lr-mupen64plus is installed by default, so you already have it.
            Btw, please try and use a descriptive title for your posts. Most people posting here need help. This is the "Help and Support" section. We assume you are in need of help. Try to put what sort of help in the title.
              Mr.Monkeyface
              sorry just learning this so do you know how i can fix it.
                mitu Global Moderator @Mr.Monkeyface
                @mr-monkeyface Update RetroPie and packages from the RetroPie menu: https://retropie.org.uk/docs/Updating-RetroPie/
