    How do I delete a rom that is causing problems when I can't type?
    newb
    32 Posts 7 Posters 7.8k Views
      dankcushions Global Moderator @PrinceGumball
      @princegumball the screenshot you posted is already in the command line, assuming yours looks the same. i don't know why you wouldn't be able to type.
      Also, I can't connect to the router with an ethernet cable, since I have my Pi set up with my TV in the living room and the router is upstairs.
      take it upstairs? you don't need to connect it to a tv to access it via the network.
      P 2 Replies Last reply Reply Quote 0
        PrinceGumball @dankcushions
        @dankcushions said in How do I delete a rom that is causing problems when I can't type?:
        How will I know what I'm doing without a screen though?
          PrinceGumball
          I'm trying really hard here. I'm not trying to be dense.
            @princegumball said in How do I delete a rom that is causing problems when I can't type?:
            because when you SSH in you are typing in commands into a terminal prompt on your laptop, or any other device connected to the network.
              PrinceGumball
              Does anyone else have any ideas?
                BuZz administrators @PrinceGumball
                @princegumball you've been given instructions already. If you can't manage it, I suggest starting from a fresh image. We don't support 3rd party images anyway.
                  PrinceGumball
                  The instructions given aren't working. Hooking the Pi up to my router via an ethernet cable is doing nothing, it's not showing up in the connected devices. I tried rebooting the router to see if that would do anything. Nothing.
                  Also, this issue is identical to the one this other person had, which WASN'T on a "3rd party image". Same game. Same error. Same terminal screen. Same not being able to type. https://retropie.org.uk/forum/topic/11389/emulationstation-crashes-after-retropie-boots-up-permission-denied/4
                  Is there NO way to stop the boot sequence? That's all I have to do. I need to be able to type the remove game command. That's all.
                  BuZzB rbakerR 2 Replies Last reply Reply Quote -1
                    @princegumball you can edit /boot/cmdline.txt and add the word single to the end - this can be done on a PC as this partition can be read. This will drop to a command prompt on boot. You can also possibly rename it over windows networking or however you copied the file on.
                    You are still probably better off re-imaging since if you can't get ssh working, I doubt you will manage the commandline aspect.
                    I don't care if the problem happens on non 3rd party images btw - why should we support those who are selling retropie ? Don't argue with our rules. If you can't get this working with the instructions given, you will have to reimage.
                    • rbakerR
                      rbaker @PrinceGumball
                      I have a Pi connected to a laptop directly with an ethernet cable right now. All you need is the ip address of the Pi and you can then SSH in with ease. I followed this. Also, typing ping retropie gives a result.
                      • lostlessL
                        lostless
                        I’m assuming that ssh is disabled. It’s off by default now. So if a keyboard is not working and ssh is off, reimaging would be the easiest option
                          PrinceGumball @BuZz
                          @buzz said in How do I delete a rom that is causing problems when I can't type?:
                          Okay, I tried that but adding the word single to the end of cmdline.txt did nothing. Still same problem, still boots up and aborts in the same spot with the same error.
                          Also I want to point out that the other person who had the identically same problem with the same game DIDN'T have a "third party image". So it's not an issue with the custom Raspberry Pi I bought.
                            I missed you saying this. Maybe I wasn't clear enough. Both me and the other person can't type after that error. Yes, it's a command line. I've found the only keys that work once it gets to that point are shift+3 and shift+~ and those just make little symbols. Can't press enter. Tried unplugging and replugging they keyboard. Nothing. Tried everything everyone has mentioned above to try to get a command line before the error comes up and that hasn't worked. The other person never said if anything worked for them.
