    Turbografx cd will not load games on RetroPie 4.3
    turbocdpc engine cdretropie 4.3roms not loadin
    5 Posts 2 Posters 1.4k Views
      cowguy27
      Hi everyone I have just recently purchased my retro pie and have everything working on it with the exception of the PC engine Cd games specifically rondo of blood. I have placed the specific BIOS In the folder as well as in the ROMs folder as instructed. The only thing that I can get to work is that the turbo will run but the screen that I get simply says PC engine cd ROM system press any button to load and when I press the button to load nothing ever happens. I have tried downloading different ROMs and I am currently using and .iso and .cue. File format to load the wrong. Is this the incorrect format I’ve been trying to get this to work for about a month now can anyone help.
      edmaul69E 4 Replies Last reply Reply Quote 0
        edmaul69 @cowguy27
        Deleted
          edmaul69 @cowguy27
          Deleted
            edmaul69 @cowguy27
            Deleted
              edmaul69 @cowguy27
              @cowguy27 i guess the first thing i should have had you try, open up the .cue file and make sure the .iso or .bin is named correctly to match the real file. So if the iso is named dRacuLa.isO you need make sure the inside of the .cue file matches that. On linux case sensitive is important. Even on the file extension.
