    360 wired/wireless and ps3 wired/wireless controller issue
    360 controllerstart button360psx-rearmedps3 controller
    1 Posts 1 Posters 623 Views
      dbroadband
      So this is a new issue after performing an update on 11/11/17. I’ve tested this using the 4 controllers listed in the topic title. I’ve also rerun the setup/update scripts just in case, but nothing changed. Deleted all the existing joypad configurations in /opt/retropie/confine/all/retroarch-joypads and remapped to no avail. Any assistance is appreciated.
      1. the start button does not function at all when starting games. It works fine in ES and the retro arch menu but as soon as an emulator launches it quits. Interestingly, turning the controller off and back on or unplugging it then replugging it fixes the issue until you exit the emulator.
      2. after getting around the above issue and into a game the dpad will constantly output up and left signals BUT this only happens in menus. It does not affect character movement outside of a menu. On/off or unplugging does not fix this one.
