    Xbox One S Controller Mapping wont work in Drastic
    xbox one scontrollerdrasticmapping
    28 Posts 3 Posters 5.8k Views
    • DarkSide1305D
      DarkSide1305
      Hello. I got myself an Xbox One S Controller, and when i try to map the Keys in Drastic, it says me for my A B X Y LB RB LT RT L3 and R3 Buttons that they are "KB unknown key"'s. How can i fix that?
      • jonnykeshJ
        jonnykesh @DarkSide1305
        @darkside1305 Weird that is reading the controller as a keyboard. Are you using xboxdrv by any chance?
        • DarkSide1305D
          DarkSide1305
          I activated it, and deactivated it. No difference :/
          • jonnykeshJ
            @darkside1305 Drop to the command line with the controller attached and run jstest /dev/input/js0 with the controller attached to see how it is being detected.
            • DarkSide1305D
              DarkSide1305
              I see a shit ton of Butoons and almost everything says "Off" when i type that in.
              • jonnykeshJ
                @darkside1305 try pressing some. Are all the buttons giving input?
                • DarkSide1305D
                  DarkSide1305
                  Almost all my Buttons make a shit ton of these Number and Stuff appear. Only the Xbox Button and the Select button make an ^@
                  • jonnykeshJ
                    @darkside1305 "numbers and stuff" that doesn't tell me if the buttons are being detected. Press A. Does one of them change from OFF to ON?
                    • DarkSide1305D
                      DarkSide1305
                      Gonna try that and tell you the Results.
                      • DarkSide1305D
                        DarkSide1305
                        Yes, every buttons turn on when i press them and off when i release then. Only the Xbox Button and Select Button wont work. And i have Xbox DVR disabled, because the Test doesnt show me Inputs when i have it activated.
                        • jonnykeshJ
                          @darkside1305 That's why I was asking about xboxdrv as it can cause issues. Looks like the controller is fully recognised by the system it should just work with DraStic.
                          Try a different controller if you have one.
                          • DarkSide1305D
                            DarkSide1305
                            My Xbox 360 Controller works fine, but not my Xbox One Controller. I use it Wireless and its an Original Controller.
                            • DarkSide1305D
                              DarkSide1305
                              I also changed the /opt/retropie/configs/all/autostart.sh and added sudo bash -c 'echo 1 > /sys/module/bluetooth/parameters/disable_ertm' because i heard that Xbox One Controllers cant connect via Bluetooth when you havent added this.
                              • DarkSide1305D
                                DarkSide1305
                                This post is deleted!
                                • DarkSide1305D
                                  DarkSide1305
                                  So @jonnykesh you have no other Idea? Because, even going into /opt/retropie/configs/nds/drastic/config/drastic.cfg i only see 10xx Buttons for Controls, not any Buttons that are from my Controller, not even my working Xbox 360.
                                  • jonnykeshJ
                                    @darkside1305 Sorry, no, DraStic should literally work with with any controller that you map to it, as long as it is recognised. The problem is on your end and specific to you or your controller unfortunately. Did you try another controller?
                                    • DarkSide1305D
                                      DarkSide1305
                                      @jonnykesh Yes, my Xbox 360 Controller, which isnt even Original, works without Problem. Only my Xbox One S Controller wont work. Also, i just realised, Select works for activating the Screensaver, but not for opening Options.
                                      • DarkSide1305D
                                        DarkSide1305
                                        And i just looked, its an Model 1708. Is that maybe the Problem?
                                        • jonnykeshJ
                                          @darkside1305 Most likely. https://retropie.org.uk/forum/topic/9249/xbox-one-controller-not-recognized/2
                                          • DarkSide1305D
                                            DarkSide1305
                                            @jonnykesh Im gonna give that Xpad Drive an try, and tell you the results afterwards.
