    Xbox One S Controller Mapping wont work in Drastic
    xbox one scontrollerdrasticmapping
    28 Posts 3 Posters 5.2k Views
    • jonnykeshJ
      jonnykesh @DarkSide1305
      @darkside1305 Maybe something in here will help. https://github.com/RetroPie/RetroPie-Setup/issues/1277
      • DarkSide1305D
        DarkSide1305
        @jonnykesh I now have xboxdvr and xpad driver uninstalled, still not working for Drastic.
        • DarkSide1305D
          DarkSide1305
          @jonnykesh I just saw, i cant install xpad, it says when i try to install it from source: "Error running 'git clone --recursive --depth 1 https://github.com/paroj/xpad.git /opt/retropie/supplementary/xpad' - returned 128", then "xpad patch retropie.diff failed to apply", then "Please see /home/pi/RetroPie-Setup/logs/rps_2017-11-13_082108.log.gz for more in depth information regarding the errors."
          • DarkSide1305D
            DarkSide1305
            Ok, my RaspberryPi decided to disconnect from my WiFi, so tha issue above is solved. Im going to try and test with Xpad now.
            • DarkSide1305D
              DarkSide1305
              @jonnykesh So. I tried now using my Xbox One S Controller Wired. And now everything works. It gets recognized as Microsoft X-Box One S Pad, and everything works, even Drastic. But, when i use my Xbox One S Controller over Bluetooth, it says its an Xbox Wireless Controller, and then the Button Layout is completely different, and i have all those Bugs. Is there any way, that you can "Trick" the RaspberryPi into thinking that my Controller over Bluetooth, is an normal wired Xbox One S Controller?
              • DarkSide1305D
                DarkSide1305
                @jonnykesh Hey, Jonny. I now found out that my Controller has for A = BTN_SOUTH, B = BTN_EAST, X = BTN_NORTH, Y = BTN_WEST, Select = KEY_BACK and Xbox-Button = KEY_HOMEPAGE. I think Drastic cant do something with South, East, North and West, Back and Homepage, but even the start Button which is BTN_START is recognized as an KB Key, and L3 and R3 which are BTN_THUMBL and BTN_THUMBR are also recognized as KB Keys. And the L1 and R1 which are BTN_TL and BTN_TR are also recognized as unknown Keyboard Keys.
                • DarkSide1305D
                  DarkSide1305
                  @jonnykesh Here is a Picture of the Buttons, when Wireless, and when Wired. https://abload.de/img/buttonsbbkog.png
                    TheMFnNiz @DarkSide1305
                    @darkside1305 did you ever solve this issue? I've tried everything listed elsewhere to no resolve. I keep getting the KB unknown key for many of the buttons I want to map. Using a bluetooth xbox one S controller. In the drastic.cfg file I notice that anything listed as KB unknown key is changed to a zero. If I knew how the emulator worked with retroarch I might be able to figure out the numbers but they do not match up with the normal 1-14 buttons retroarch uses.
