    *SOLVED* [Help Retropie 4.3] Some MAME2003 roms not working after update
    retropie 4.3mame2003
    54 Posts 8 Posters 15.3k Views
    • MrJordaaanyM
      MrJordaaany
      Hey all,
      I've got an issue on my retropie for v4.3. After updating, some roms in mame2003 that worked fine now crash on boot. They never use to before I updated. Theres about 4 or 5 so far but for this example I will use:
      *Elevator Action Returns (elvact2u.zip)
      *Vigilante (vigilant.zip)
      Yes the are from the right romset: MAME 0.78 (MAME 2003). The roms are not the issue.
      Both of these roms work on a fresh 4.3 image, so I know it's either something to do with my setup (configurations etc.) or a setting in mame2003 or something. I have launched both roms with verbose logging enabled, and the results are below. Sorry for the large copy and paste.
      Elevator Action Returns : https://pastebin.com/NFvQLB6b
      Vigilante https://pastebin.com/x5Uhy8bT
      I am guessing the issue is something to do with the bottom lines here:
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1014:  3204 Segmentation fault      SDL_VIDEO_EGL_DRIVER=/opt/vc/lib/libEGL.so SDL_VIDEO_GL_DRIVER=/opt/vc/lib/libGLESv2.so /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003/mame2003_libretro.so --config
      But I am not sure what to make of them. Both runcommand and Mame2003 are up to date.
      Thanks in advance for any help!
        dankcushions Global Moderator
        one of @gamez-fan’s driver changes?
        • MrJordaaanyM
          MrJordaaany
          Well a stock 4.3 image works fine.
          I've updated a bunch of times since though, so maybe? Can anyone else test?
          I am reading this thread right now actually:
          https://retropie.org.uk/forum/topic/13638/lr-mame2003-driver-improvement-and-backport/67
          I'm getting errors out the ass when I try to do a source install. I have uninstalled completely and done a fresh binary install now though. Will test.
            dankcushions Global Moderator @MrJordaaany
            @mrjordaaany a stock image wouldn’t have their latest updates.
            i believe all these changes seem to be getting accepted untested so personally i wouldn’t update unless you’re prepared for it to break! i will try and test soon but not sure when.
            arcadez2003A 1 Reply Last reply Reply Quote 0
            • MrJordaaanyM
              MrJordaaany
              Nope still not working on a fresh from binary install.
              Vigilante is made by Irem and Elevator Action is made by Tatio. Other games by these devs work fine.
              • arcadez2003A
                arcadez2003 @dankcushions
                @dankcushions said in [Help Retropie 4.3] Some MAME2003 roms not working after update:
                Yes the changes are untested although 99% of them should not affect anything other than the games and drivers in question eg i've worked on no source files connected to
                vigilante or Elevator Action, it's mostly just adding or fixing up games that were not playable in MAME78 or were missing sound support, but i'll certainly look back over all my
                commits to see if any of them might cause more general game breakage across the core.
                Arcade Addict
                  dankcushions Global Moderator @arcadez2003
                  @gamez-fan if the compile is broken then it affects everyone no matter what games they play ;)
                  do you not have a raspberry pi to test compilations on? if not i believe it's possible to cross-compile for a pi/ARM target on a regular PC, but i haven't attempted that.
                  i would like to help test these things but to be honest it's too many changes for me to keep up.
                  • arcadez2003A
                    Sure of course if the overall build does not compile then every game will be broken per say, im looking over all of my previous commits currantly
                    to try and pindown the cause of the above problems, and yes as you suspected i dont have an Rpi or have even done a full compile of my
                    changes i was using an MAME76 Xbox source to compile each code change to make sure it's compatable with the MAME78 src as it's
                    more or less on a par with MAME76 anyway with regards to the code i have been tinkering with
                    Arcade Addict
                    MrJordaaanyM 1 Reply Last reply Reply Quote 0
                    • MrJordaaanyM
                      MrJordaaany @arcadez2003
                      @gamez-fan Hey thanks for looking into this. Really great of you.
                      I have other examples too: Air Duel (arduel.zip) Strikers 1945 II and III as well (s1945ii.zip and s1945iii.zip). Alien3 (alien3.zip) used t o work fine too but now crashes not long after you start the game.
                      As said I've tried removing configs, copying across fresh roms etc. But testing them all against a fresh 4.3 image there is no issue with them.
                      • arcadez2003A
                        arcadez2003 @MrJordaaany
                        @mrjordaaany said in [Help Retropie 4.3] Some MAME2003 roms not working after update:
                        yeah some of the above games are from drivers i've worked on im going to propose that we roll back the MAME-2003 libretro core to before my
                        very first commit to fix the build and then i'll take the time to fully compile and test my changes as breaking lots of games while add the
                        extra one or two is not a road a want to go down.
                        Arcade Addict
                        MrJordaaanyM 1 Reply Last reply Reply Quote 1
                        • MrJordaaanyM
                          @gamez-fan Hey thanks, I really appreciate that :) So if mame2003 is rolled back, would simply updating it from RetroPie Setup fix it. Or is it best to unistall, then reinstall the mame2003 emulator?
                          • arcadez2003A
                            Im waiting for a response from the dev's but yes after the core is reverted you'll just have to download and reinstall the fixed version
                            Arcade Addict
                            • MrJordaaanyM
                              @gamez-fan Sweet sounds good. Thank you.
                              • arcadez2003A
                                arcadez2003
                                Ok im been studying my commits and the code looks from my end 100% correct on the MAME side maybe the problems being reported
                                with certain games now not working might be an issue with the Libretro side of the sources which to be honest i dont have much experience
                                with.
                                Lets take Gunbarich as an example i recently added that game to the psikyosh driver which is the same one which also supports Strikers 1945 II / III
                                were talking a little eeprom code for the game plus the Rom the inputs and finally the speedups all this code is isolated to Gunbarich thats to say
                                no other code games like Strikers 1945 use has been altered in any way shape or form so im at a loss as to why this could break any game that
                                was previously supported in that driver.
                                But i have a hunch of what might be causing these problems maybe the addition of the dreamwld.c driver needs to be declared in more areas
                                of the source than just the makefile.?? and that might be throwing the emulater off when it has been built from the latest sources i dunno for
                                sure yet but @MrJordaaany since you can compile the latest sources would you like to test a change for me..?? i'll send you a arc with dreamwld.c
                                removed to see if that will sort the issues you have reported just simply delete dreamwld.c from the driver folder in your compiler options
                                i've already removed it from the main source.
                                [url]http://www54.zippyshare.com/v/5QUXvwGq/file.html[/url]
                                Arcade Addict
                                markwkiddM MrJordaaanyM 2 Replies Last reply Reply Quote 0
                                • markwkiddM
                                  markwkidd @arcadez2003
                                  @gamez-fan once a libretro build environment is set up the first time, it is very easy to compile libretro cores for testing purposes.
                                  Are you interested in setting up your environment? If you provide your operating system I'm glad to help you get it done quickly and painlessly. I think your project is very important so I'm motivated to help any way I can! :)
                                  arcadez2003A RiverstormR 2 Replies Last reply Reply Quote 0
                                  • MrJordaaanyM
                                    @gamez-fan I don't really know how to compile past using the 'install/upgrade from srouce' option under Retropie Setup. Is it not easier to roll back for now and do some testing before pushing another update?
                                    I am more than happy to test though, I just need to know how to apply the update above. Is it as easy as deleting the dreamwld.c file from the drivers folder? Or do I have to be in some compile mode?
                                    Cheers
                                    • arcadez2003A
                                      arcadez2003
                                      It's ok fellas i'll build a dev environment and test the code changes myself but it wont be for a while as i dont have the time
                                      right now but as i said i've proposed we just roll back the mainline mame-2003 source in the meantime to fix any problems
                                      in the build.
                                      But being as im not the custodian of the project it's outta my hands as such i have raised an issues flag over at the git and
                                      no one seems all that fussed TBH i guess maybe their waiting to see if more users have similar problems across all
                                      the platforms that use this core before acting..??
                                      Arcade Addict
                                      • MrJordaaanyM
                                        @gamez-fan Dam sounds like the only way to fix my issues for now is to use a fresh 4.3 image.
                                        Is there nothing I could maybe copy (file-wise) from a 4.3 fresh image of mame2003 into my current image to revert the changes?
                                        If not im happy waiting while people test things.
                                        Thanks for all your help!
                                        • arcadez2003A
                                          arcadez2003
                                          TBH i was justing working with the MAME code in the mainline source i know nothing about what you mention above
                                          with regards to images etc etc best i can do is drop a copy of the MAME-2003 libretro core which has all my commits
                                          removed maybe someone can then compile it to help you create an image..??
                                          [url]http://www97.zippyshare.com/v/TRlaM9H7/file.html[/url]
                                          Arcade Addict
                                          • MrJordaaanyM
                                            @gamez-fan No problem. I see if I can compile something up then aye? Again thanks for your help :)
