    Need Help with getting a B-Wings ROM to work in MAME4ALL
    b-wingsmame4allromneed help
    6 Posts 5 Posters 1.3k Views
    • N
      norbit2
      Hi, first time posting here and my first Retropie. I am desperately trying to find a working ROM version of B-Wings (Japanese game) for MAME4ALL for my retro pie. Any versions I have tried that I find do not open and go right back to the game list. I am simply dragging the zip file onto the Pie via my MacBook Pro shared network drives. Does anyone have a link to a B-Wing ROM that would work for me? Thank you. I am an amateur at this, I apologize if I have not used the correct lingual or posted adaquate info.
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) B. / RP 3.0
      Power Supply used: (If using a Pi): 5.1V. 2.5A
      RetroPie Version Used 4.2.3
      Built From: Not Sure
      USB Devices connected:
      Controller used: Old Skool SNES USB controller
      Emulator: MAME4ALL
      jonnykeshJ RiverstormR 2 Replies Last reply Reply Quote -1
      • jonnykeshJ
        jonnykesh @norbit2
        @norbit2 Please do not ask for links to ROMs or where to obtain ROMs. That is not what this forum is for and it is pretty much rule number one.
          Pussyfoot
          You shouldn't be using MAME4ALL. You should use MAME 2003 or 2010.
          • N
            norbit2 @jonnykesh
            @jonnykesh Sorry, did not know. Where do I go for help then for this?
            • herb_fargusH
              herb_fargus administrators @norbit2
              @norbit2 this is a good place to start. https://retropie.org.uk/docs/Arcade/
              • RiverstormR
                Riverstorm @norbit2
                @norbit2 said in Need Help with getting a B-Wings ROM to work in MAME4ALL:
                I think your issue is mame4all nor lr-mame2000 support B-Wings. You'll need to upgrade to lr-mame2003 for it to work.
