    Arcade control panel mapping questions
    mameretroarchcontrol panelipac4noob
    44 Posts 4 Posters 10.6k Views
      SammyLJ @caver01
      @caver01 so I changed the emulation station buttons and it changed the in game buttons as well....
        SammyLJ
        ok wait a minute
        this whole time I have been changing /all/retroarch.cfg
        should I have been changing /mamelibretro/retroarch.cfg
          SammyLJ
          so I got everything to work in game. I even figured out how to exit from the games. Escape alone doesn't seem to work but player 1 select(num5) is set to be the hot key and that plus escape backs out of games. That seems to be the only way I can get it to work. The runcommand no longer comes up when I hold player 2 down not sure what it did but I changed some stuff and it worked.
          so we are basically all good and playing.
          I wish I could change the emulation station menu buttons but when I do it changes everything.
          • caver01C
            caver01 @SammyLJ
            @sammylj Hmm. That escape exit situation sounds like you still have hotkeys enabled. Scan through your retroarch.cfg for hotkey and set it to "nul" or comment out the setting. I am running with a dedicated exit (escape) and I don't need to press anything else, just my single exit button.
