    PC Engine build
    pc enginetg16pcebuildturbografx
    59 Posts 15 Posters 22.3k Views
    • DarksaviorD
      Darksavior @FlyingTomahawk
      @flyingtomahawk Me too. PC Engine's that look like they were used as a doorstop are way too expensive and the nearmint ones are even more. I wanted to solder a microsd usb reader to a hucard's pins but that also might've been near impossible.
        @flyingtomahawk said in PC Engine build:
        ~~So how do you get those games/roms into the hucards? Where did you get the python script from to let it read that game data and then run them?
        There's a NES mini build with NFC support explained at http://www.daftmike.com/p/nespi-software-install-guide_30.html. The concept I think is the same - read the NFC card label and then execute a command on the Pi. Note that the game is not on the card, it's just the name of the game. The script reads the NFC label (name of the game), searches for the ROM file (on the Pi) and then executes runcommand with the proper parameters to start the emulator for the ROM name found on the NFC card.
        The code used is published at https://github.com/imdaftmike/NESPi.git .
        FlyingTomahawkF 1 Reply Last reply Reply Quote 1
        • FlyingTomahawkF
          FlyingTomahawk @mitu
          Now that makes sense.
          So the the card is just a trigger to load the rom which is on the SD card. Cool stuff!
          • FlyingTomahawkF
            FlyingTomahawk
            @ruckage
            Sorry to go again off-topic with the following question.
            I was looking at SD cards on amazon and they offer 2 types of SanDisk Ultras.
            One is red/grey and says Class10 / A1 Sandisk microSDHC 98mb/S GB Ultra SD
            They other is white/grey and says Class10 Sandisk microSDHC Ultra 80MB/s GB
            Can the Pi read either one?
            • ruckageR
              ruckage @FlyingTomahawk
              @flyingtomahawk
              Hi. Yes, both should work. A1 should technically be better I think (it's a new rating that I believe signifies good 4KB read/write performance which from my reading is important when it comes to the pi). My current card is A1 and works perfectly. Just make sure to buy directly from Amazon themselves as there are a lot of fake SD cards around.
              Regarding your previous question, @mitu description is correct. Mine is slightly different to daftmikes as I don't have an arduino as a middleman reading the tags, instead I have it connected directly to the gpio and I'm using a python library to read the tags ndef data. To write the tags I'm just using my tablet and an app which i think is called nfctool. Daftmikes software is much more advanced than mine as it handles multiple systems and can also write the tags, I didn't need that so mine is quite simple.
              I'd post a link to the tutorial I followed but the site doesn't seem to be working, there is a google cache of it though https://webcache.googleusercontent.com/search?q=cache:fPoZv3oSw_kJ:blog.digitaloctave.com/posts/hardware/nfc-module-v3-raspberry-pi/+&cd=1&hl=en&ct=clnk&gl=uk
              My code is based on the sample from that tutorial, I'll post my code below though I'll probably tweak it some more before I'm finished, it could be simplified (particularly where it joins the strings to create the command) but I'm trying to keep it easily readable.
              import subprocess
              import nfc
              import ndef
              from nfc.tag import tt1
              from nfc.tag import tt2
              from nfc.tag import tt3
              from nfc.tag import tt4
              tagtypes = (
                  ('uid', nfc.tag.tt1.Type1Tag),
                  ('uid', nfc.tag.tt2.Type2Tag),
                  ('idm', nfc.tag.tt3.Type3Tag),
                  ('uid', nfc.tag.tt4.Type4Tag)
              with nfc.ContactlessFrontend('tty:S0:pn532') as clf:
                  tag = clf.connect(rdwr={'on-connect': lambda tag: False})
                  record = tag.ndef.message[0]
                  rom = nfc.ndef.TextRecord(record).text
                  rom = rom + ".zip"
                  path = "\"/home/pi/RetroPie/roms/pcengine/"
                  command = "sudo /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ pcengine "
                  command=command+path+rom+"\""
                  subprocess.call(command, shell=True)
              Edit: Forgot to say, daftmike is a really nice helpful guy. I've sent him a few emails and he kindly pointed me in the right direction to buy an NFC reader after my fake one didn't work as expected.
              FlyingTomahawkF 1 Reply Last reply Reply Quote 3
              • FlyingTomahawkF
                FlyingTomahawk @ruckage
                @ruckage
                Thanks a lot for explaining. Now things start to make sense.
                Regarding my boot time, not sure why but I had a 16GB Class 4 SD card inside my Pi3. That might explain why I had slow loading times. I have a 32GB SanDisk Ultra Class 10 A1 coming my way now that should hopefully speed things up a bit.
                • ruckageR
                  @flyingtomahawk
                  You should definitely notice a difference going from a class 4 to class 10 SD card, will be interesting to see your boot times with the new card.
                  The cable you're looking for is just called a 'micro sd extension cable'
                  I think this is the one I bought but they should be fairly easy to find on ebay/amazon as well.
                  https://shop.pimoroni.com/products/microsd-extension-cable
                  • FlyingTomahawkF
                    @ruckage
                    Thank you.
                    I found the cable info in your SNES build right after I wrote here that is why I removed it.
                    Will order it now and see where to put it inside my Famicom.
                    • ruckageR
                      @flyingtomahawk
                      :D I hadn't even noticed you removed that from your message.
                      I can't think of anywhere obvious you could put the extension cable apart from maybe in the cartridge slot. I'll have to have a look at my famicom as I can't remember what ports it has and I'll likely use an extension cable as well when I do my famicom mod.
                      • FlyingTomahawkF
                        FlyingTomahawk
                        Got my SanDisk Ultra Class10 A1 SD card today and slapped on my backup image file.
                        I did 10 boot ups and I get 9 seconds to boot video and 15 seconds to menu consistent. No ups or downs in boot time, always 9 and 15.
                        Maybe if I remove the splash video I can get the time lower but then all the fun is gone and I really like the splash video.
                        ruckageR 1 Reply Last reply Reply Quote 1
                        • ruckageR
                          @flyingtomahawk
                          That's a nice improvement. You might find that ES is already loaded a bit before that and the splash video is playing over the top of it. Could you try without the splash video to get an accurate boot time?
                          What splash video are you using by the way?
                          FlyingTomahawkF 1 Reply Last reply Reply Quote 0
                          • FlyingTomahawkF
                            @ruckage
                            Your splash video of course. :-D
                            Definitely an improvement. Thanks to you and this thread here I went from 23 boot video 29 menu to 9 boot video 15 menu.
                            If I disable the splash video I cut the time by 1 second. I rather wait 1 second and enjoy a nice splash video.
                            And here an old video of mine. Look at that long boot time, terrible.
                            • ruckageR
                              @flyingtomahawk
                              Yep, that's definitely a speed improvement.
                              Nice to see my splash videos being used. I was going to offer to shorten the splash video to match your boot time but to be honest that looks nice and seamless, pretty much identical to the boot on my super famicom which isn't surprising as it's using the same SD card and I designed the length of the video with that in mind.
                              It's a shame that there is such a delay before splash videos start playing in Retropie, it would be nice to be able reduce that but I guess they play as early as is possible.
                              @herb_fargus A quick question, with plymouth boot screens do they start earlier in the boot process or is it comparable to splashvideos?
                              herb_fargusH 1 Reply Last reply Reply Quote 1
                              • herb_fargusH
                                herb_fargus administrators @ruckage
                                @ruckage said in PC Engine build:
                                It's a little earlier but essentially negligible. You'd see a bit more of a difference on the pi 1. But even then it's just a matter of seconds.
                                • ruckageR
                                  ruckage @herb_fargus
                                  @herb_fargus
                                  Thanks.
                                  • Stuart2773S
                                    Stuart2773 @ruckage
                                    @stuart2773 said in PC Engine build:
                                    @ruckage Can't wait to see what "theme" you come up with for this build
                                    I'm sorry to disappoint you but this build won't be using ES at all so it won't have a theme, all games will be launched by inserting my fake Hucards (I have enough plastic blanks to make 100 at least which will easily cover all the PC Engine games I'm interested in.
                                    Sorry to hear that you wont be making a theme for this build :(
                                    however, if its not too much trouble to kindly ask if you would consider modifying your neogeo theme as i would love to use that theme for my PC Engine build to support "CD front covers", i had a look at the xml files but im not sure what the position and alignments would be, if it is at all possible that you could modify the xml files i can easily make my own background images for my own personal use.
                                    Ive included a pic (see pic below) of what i done, i just extended the game selection & controls screen and reduced the boxart/screenshot section, obviously the aes-controls.png would need to centered in its new position and the game selection names would need to be extended.
                                    many thanks
                                    stuart.
                                      skj @Stuart2773
                                      @stuart2773
                                      Wow 😃 That square layout is really nice for CD size box images, would work well for a lot of other systems too šŸ‘šŸ»
                                      • chelochelini2014C
                                        chelochelini2014
                                        I gave my rp3 as a gift , no problem, i solved the problem with a very cheap deal
                                        https://imgur.com/a/cZImx
                                        • I
                                          iVirtualZero @ruckage
                                          @ruckage Not fan of these emulator boxes. There are way too many other emulation boxes that do a better job like the Nvidia Shield TV. Original OEM Hardware will always be the best and can never truly be replaced. You can use your carts, flash carts, HDMI adaptors, original pads, pheriperals, no lag, and no glitches. Ps i’m looking for parts to repair my PC Engine let me know if you plan on selling the original motherboard.
                                          1 Reply Last reply Reply Quote -2
