    I need help. (Could not expand filesytem)
    helpsupport
    11 Posts 3 Posters 3.0k Views
      Pesto
      I just got my pie in the mail today. I set everything up. I tried to run the pie but it says " Could not expand filesytem, please try raspi-config or rc_gui.
      Boot and root partitions are on different devices" What should I do?
      jonnykeshJ mituM 2 Replies Last reply Reply Quote 0
      • jonnykeshJ
        jonnykesh @Pesto
        @pesto Hello. You need to provide the information requested here https://retropie.org.uk/forum/topic/3/read-this-first before anyone can begin to help you.
        Did you try expanding via the raspi-configmenu?
          Pesto @jonnykesh
          @jonnykesh How would I do that? I'm new to raspberry pie and retro pie.
          • jonnykeshJ
            jonnykesh @Pesto
            @pesto https://www.raspberrypi.org/documentation/configuration/raspi-config.md
              Pesto @jonnykesh
              @jonnykesh It still won't let me access the config. The screen is just blue and says " Could not expand filesytem, please try raspi-config or rc_gui.
              • jonnykeshJ
                jonnykesh @Pesto
                @pesto Okay. It was worth trying first. You need to provide the info about your setup. As I previously requested.
                  Pesto @jonnykesh
                  @jonnykesh Your asking for what type of raspberry pie I'm using? I'm using Pi 3 model B
                  • jonnykeshJ
                    jonnykesh @Pesto
                    @pesto I'm asking you to provide the information requested in the link I posted above.
                      Pesto @jonnykesh
                      @jonnykesh The link tells me how to access the config. Which I can't.
                      • jonnykeshJ
                        jonnykesh @Pesto
                        @pesto The one above that.
                        Sorry dude, if you can't post basic info and follow basic instructions I can't help you. Hopefully someone with more time and patience will offer to assist.
                          mitu Global Moderator @Pesto
                          @pesto Do you intend to run RetroPie on the PI ? Then follow the steps in https://retropie.org.uk/docs/First-Installation/ (there's a handy video included) and you should be good to go. You don't need to expand the filesystem in order to install RetroPie.
