    Runcommand launch images automatically chosen for ROM-specific emulatorchoices
    arcade foldermamefbaromsruncommand
    55 Posts 6 Posters 9.7k Views
      meleu @AndersHP
      @andershp hey, are you still interested in this stuff?
      I've made some changes on the script, taking care of those different mame system folders, and maybe it can work now. Again: I didn't test it on an actual RetroPie.
      If you wanna give this another try, Just remove from your runcommand-onstart.sh my previous code you added a few days ago (or delete the file if you had nothing there before).
      And then try again the same steps I mentioned on a previous post:
      https://retropie.org.uk/forum/post/126827
      AndersHPA 2 Replies Last reply Reply Quote 1
      • AndersHPA
        AndersHP @meleu
        @meleu said in Runcommand launch images automatically chosen for ROM-specific emulatorchoices:
        What do you mean? Of course!
        Cool, will try it again and post back here :)
        My Gameboy
        • AndersHPA
          AndersHP @meleu
          @meleu I just tested, and nothing changed... Still not working.
          The script is 3.750 kb, is this the new version?
          My Gameboy
          • AndersHPA
            AndersHP
            @meleu ?
            My Gameboy
              meleu @AndersHP
              @andershp I'll be able to code and test my code on a real RetroPie system in a couple of days. I hope I find a definitive solution for this.
              Wait a little.
                meleu @AndersHP
                @andershp hey bro! I fixed the script and tested. Seems to be working fine now.
                Could you test it again?
                By the way, the problem was just that I missed the -launching on the filenames. 😅
                • AndersHPA
                  AndersHP
                  Sweet! I will test it tonight. Thanks! :)
                  My Gameboy
                  • AndersHPA
                    AndersHP
                    Sorry, man. It's not working for me.. I'm starting to feel like something's wrong with me..
                    The new runcommand-onstart looks like this, correct?
                    I'm still not understanding that some of the lines contain "mame" - shouldn't it be either mame-advmame or mame-libretro? (see here)
                    So, just to be sure my setup is not wrong; my 3 launching images are placed here:
                    /opt/retropie/configs/mame-libretro/launching.png
                    /opt/retropie/configs/mame-advmame/launching.png
                    /opt/retropie/configs/fba/launching.png
                    My Gameboy
                      meleu @AndersHP
                      Nop. You're using the previous version. Delete the file and perform those commands again.
                      AndersHPA 1 Reply Last reply Reply Quote 0
                      • AndersHPA
                        AndersHP @meleu
                        @meleu that's what I did.. Strange. Will do it again, but how can it wget an old version?
                        My Gameboy
                          meleu @AndersHP
                          @andershp said in Runcommand launch images automatically chosen for ROM-specific emulatorchoices:
                          Another possible problem can be related to that cat command.
                          Well, if you can understand a github diff, look here the only line I changed to fix the code:
                          https://github.com/meleu/share/commit/c31f3f47ad2f790c2c5f7acb66b7db9100bd892e
                          And if you're still having problems to get the current version, maybe you can edit the file yourself.
                          • AndersHPA
                            AndersHP @meleu
                            @meleu Allright, I get the diff principle, so I'll alter it manually.
                            But again.... I still don't understand how the script gets to mame-libretro or mame-advmame. Looks like it only distinguishes between fba and mame..?
                            My Gameboy
                              meleu @AndersHP
                              I've just noticed you're still using the very first version of my script. I already fixed the mame names. Look the diff:
                              https://github.com/meleu/share/commit/bf5f6d6c090dc63cfcfd8e4ed90a927e14b2062d#diff-8aa1e6dea1743cf6d899871b9e804436
                              I think I know what's happening. When you use wget and there's a file with the same name of the one you're trying to download, wget creates the newer with a trailing .1. Then when you use the cat trick you're not "installing" the new script.
                              My suggestion:
                              rm system_specific_arcade_launching_images*
                              sudo mv /opt/retropie/configs/all/runcommand-onstart.sh /opt/retropie/configs/all/runcommand-onstart.sh.bak
                              wget https://raw.githubusercontent.com/meleu/share/master/system_specific_arcade_launching_images.sh
                              cat system_specific_arcade_launching_images.sh >> /opt/retropie/configs/all/runcommand-onstart.sh
                              AndersHPA cyperghostC 2 Replies Last reply Reply Quote 1
                              • AndersHPA
                                AndersHP @meleu
                                Jesus! That's obvious! I feel like a complete tool! :-D
                                Well, impressive that you managed to improve the script several times with me just saying "first version didn't work" :-)
                                I will test properly again, tonight. Got a good feeling about it this time, hehe !
                                My Gameboy
                                  cyperghost @meleu
                                  @meleu Just a suggestion.
                                  I think it would be better to use runcommand-onxxxx.sh just as entrypoints for calling scripts. Therefore I would modify your installer to .... ;)
                                  mkdir /home/pi/RetroPie/scripts
                                  mv system_specific_arcade_launching_images.sh /home/pi/RetroPie/scripts
                                  chmod +x /home/pi/RetroPie/scripts/system_specific_arcade_launching_images.sh
                                  echo '/home/pi/RetroPie/scripts/system_specific_arcade_launching_images.sh $1 $2 "$3"' >> /opt/retropie/configs/all/runcommand-onstart.sh
                                  PS: I think it will also help lots of people if there would be a small "instruction" inside both runcommand-onxxxx.sh files!
                                  # Example runcommand-onstart.sh
                                  # --- BASENAMES ---
                                  rom="$3"
                                  es_system="$1"
                                  emulator_used="$2"
                                  # --- ROMname Manipulation ---
                                  #rom_name="$(basename "$rom")"
                                  #rom_path="$(dirname "$rom")"
                                  #rom_no_ext="${rom_name%.*}"
                                  # --- Configfile Playground ---
                                  #config_dir="/opt/retropie/configs/$es_system"
                                  #config_dir="/opt/retropie/configs/all"
                                  #config_file="$config_dir/retroarch.cfg"
                                  # --- YOUR SCRIPTS HERE ---
                                  /home/pi/RetroPie/scripts/system_specific_arcade_launching_images.sh "$es_system" "$emulator_used" "$rom"
                                  • AndersHPA
                                    AndersHP
                                    So, with this new runcommand-onstart file, I'm afraid, still no launch images shows :(
                                    What can I do to help? Could it be because my games are run off USB?
                                    My Gameboy
                                      meleu @AndersHP
                                      Ouch!!! You can't create symbolic links on FAT partitions!
                                      EDIT: yes. That's the cause.
                                      Can you please launch an arcade game and then check what's in the /dev/shm/runcommand.log (post it on pastebin)?
                                      • AndersHPA
                                        AndersHP
                                        Absolutely, good sir. Here's one for fba and one for mame2003:
                                        fba 1942
                                        mame-libretro 005
                                        Should I also mention that I moved my artwork from roms/arcade/images to the default emulationstation/downloaded_images? Don't know if that's relevant.
                                        My Gameboy
                                        cyperghostC meleuM 2 Replies Last reply Reply Quote 0
                                          cyperghost @AndersHP
                                          @andershp That's relevant!
                                          If this fileformat is ext3/4 then this script should work!
                                          Change path in line 9 and test it!
                                          @meleu I think define a new parameter with path were the images are stored!
                                          [ -z "$4" ] && local arcade_imgs_dir="$HOME/RetroPie/roms/arcade/images" || local arcade_imgs_dir="$4"
                                          I assume that the script should work even with changed pathes ;)
                                            I feel like in a RPG. Each step taken results in a new little bit of information. :D
                                            I'm currently enjoying the brazilian carnival. Will be able to take a look at it next week. ;)
