    Help me please (storage issue)
    retropiememorymemory cardhelp
    18 Posts 6 Posters 4.6k Views
      devin_205
      i recently have got a raspberry pi 3 b and and got a sd card with 120 gb or storage on it and i followed a guide on how to set it up but i have one problem ... it says that i only have 56.8 mb on it and can only store 56.8 mb worth of roms and i tried expand storage and a few other things but it wont expand the storage please help me
      danielmewhouseD edmaul69E 2 Replies Last reply Reply Quote 0
      • danielmewhouseD
        danielmewhouse @devin_205
        @devin_205 you have to "expand file system" to get the right space. Look in the Raspi Config menu for this feature.
        It's no use!!! Take this!!!
          devin_205
          I have already tried that it doesnt work for some reason if you have a skype or discord i can show you
          danielmewhouseD 1 Reply Last reply Reply Quote 0
          • danielmewhouseD
            @devin_205 sorry, didn't see that you've tryed this on the first post. Other possibility is you have a false sdcard. I live in Brazil and this is common here: you buy a sdcard with large storage, it's showed on Windows this size, but when you reach a certain storage consumption, it says "no more space allowed" or something like this... Could be the same thing...
              devin_205
              i can send you the link off of amazon of where i got it
              • isrnickI
                isrnick
                How are you accessing this storage? Is the SD on the retropie? Are you viewing the roms folder through windows network (samba)?
                  devin_205
                  both
                  isrnickI 1 Reply Last reply Reply Quote 0
                  • isrnickI
                    isrnick @devin_205
                    @devin_205 said in Help me please:
                    both
                    So when you try to transfer something bigger than 56.8 MB to your roms folder through your network it fails?
                    • simonsterS
                      simonster
                      If you put the sd card in a pc, you are only seeing the boot/config partition. You need to put it in the Pi and transfer ROMs to it by usb or network, check the documentation.
                        edmaul69 @devin_205
                        @devin_205 56mb is the boot partition. Windows cannot see the linux partion so stop trying to expand it in windows. You are going to mess up the image doing that.
                          devin_205
                          if i pree f11 on my keyboard on retro pi it says i have 119 gb on/* but my storage is on /boot
                            edmaul69 @devin_205
                            @devin_205 boot is only the boot partition. Your roms dont go there. You cant see the linux partition in windows
                              devin_205
                              if i go to network then go to my raspberry pi and input roms it says i dont have enough storage on the device
                              • isrnickI
                                isrnick
                                See the documentation for ways to transfer roms to retropie:
                                https://github.com/RetroPie/RetroPie-Setup/wiki/Transferring-Roms
                                  devin_205
                                  im gonna check out the link but does anyone have a discord or skype im alot better speaking then typing sorry
                                  • simonsterS
                                    simonster
                                    There is an issue with UNC shares and windows when there is no password required. I can't find the thread discussing it at the moment.
                                      devin_205
                                      0_1515891536788_idk..PNG it says cant upload a psx rom
                                        Clyde @devin_205
                                        @devin_205 Do you have an USB stick you can use for the transfer? Then use the USB method described in the link @isrnick gave you. It should be the easiest way if you have problems transferring roms over the network.
                                        Please describe exactly what you did and give us the exact error message(s).
