    Usb ports doesn't work on retropie but does eork on raspian
    controller portusb gamepadretropie 4.3raspberry pi 3braspberrypi 3b
    9 Posts 3 Posters 1.4k Views
      alfon50
      My raspberry pie 3 was working on retropie for a couple days. One day I was playing kingdom hearts birth by sleep on my raspberry pi 3 using a psp emulator on retropie until I was in the middle of a cut scene and my brother threw up a bit next to the retropie and like a drop of saliva got on the gpio and the controller stopped working and none of the usb ports seemed to work . For a couple days i was thinking that it was water damaged but then 2 days after i clean it using a tooth brush and rubbing alcohol to clean in case of any corrosion. The next day i try and reset it with raspian and next thing you know the usb ports start working the controller gets detected and the keyboard works unlike before. I reset the pi and get retropie on it and again the controllers stopped working. Do any of you know what could be wrong?
        mitu Global Moderator @alfon50
        @alfon50 Something messed up the controller config. The RetroPie image is Raspbian underneath, it's not a separate OS in itself. I'd suggest you reset you controller config and re-configure them.
        A 2 Replies Last reply Reply Quote 0
          alfon50 @mitu
          @mitu I can't config the controller because it won't detect my controller or a keyboard
            alfon50 @mitu
            @mitu wait i redownloaded raspbian and the ports stopped working there too
              edmaul69 @alfon50
              @alfon50 if it got on the gpio, did you lift up the black plastic and scrub under that too?
                alfon50 @edmaul69
                @edmaul69 no i did not but i will try and do that too and update you guys
                  alfon50 @edmaul69
                  @edmaul69 wait you can lift up the black plastic from the gpio? I wasnt aware i am new to raspberry pi
                    edmaul69 @alfon50
                    @alfon50 get a precision flathead screwdriver and start on one end. Slowly and carefully twist the screwdriver a little to get it to lift a little then move down a little and twist the screwdriver a little. Just keep doing that going back and forth until it is lifted of. Scrub both the board and the black plastic piece when its off with your toothbrush and 91% isopropyl alchohol.
                      alfon50 @edmaul69
                      @edmaul69 alright tnx guys i attempted this and it work :) tnx for the help guys i guess i didn't clean it well the first time
