    BattleZone mame2003 input issue
    mame2003service menu
    27 Posts 4 Posters 5.6k Views
      mediamogul Global Moderator @FlightRisk
      @flightrisk
      Changing display_artwork_crop yes to 'no' should do the trick.
      • FlightRiskF
        FlightRisk
        I feel 20 again! LOL. Thanks everyone. It is beautiful! Maybe now I'll play with a lot of those other settings like "flicker" to see what happens. I'm happy the way it is now, the rest will be fun just to see if I can get it the way my game used to look in my arcade. There isn't a dynamic option for editing the file in something like the tab menu, is there?
        And last item, the game screen has about 1/8" overspill on the left and 1/4" on the right (the mountains and horizon bleed into the bezel). There is 1/2" of black on the right and left sides of the bezel at the monitors edge (so it doesnt' seem to be going edge to edge width wise). So I'm not sure if this is settings in the art file for the bezel or some other positioning sizing thing.
        caver01C mediamogulM 2 Replies Last reply Reply Quote 0
        • caver01C
          caver01 @FlightRisk
          @flightrisk said in BattleZone mame2003 input issue:
          I will have to check my setup to see if there is vector imagery bleeding over the bezel/overlay, but the black on the sides is likely a result of screen size. For example, on my 5:4 display, I don't see nearly as much of the sides of the artwork, as this is pushed completely off the screen if I recall. Widescreen TVs will have more space that might not get covered by the artwork which was built from the actual arcade game during a time when there were no wide screens.
            You should be able to invoke the menu using the 'Tab' key. If not, look at your input_map[ui_configure] setting to see what key is currently set. Keep in mind that, while convenient, not all options can be set from this menu.
            I haven't noticed this myself, but it could be intentional to emulate the overscan from the original cabinet. I imagine it's configurable by unzipping the bzone.zip art file and adjusting how it's displayed within the bezel, but I've never tried it personally.
            Edit: If you mean that the vector art is bleeding on top and not behind the bezel then I'm not really sure.
            • FlightRiskF
              FlightRisk
              Thanks. Is this rom setup for free play? I don't see anything referencing "insert coin". And if you want to adjust flicker, scanlines, etc. for just this rom or just vector games, is there a way to do that? MameUI had a feature for slide controls and they would appear at the bottom of the screen and you could adjust phosphor life, bloom, etc.
              mediamogulM caver01C 2 Replies Last reply Reply Quote 0
                All games share the same setting for insering a coin. This can be overwritten on a per-game basis, but by default, the universal setting for player one is input_map[coin1] in the advmame.rc file, or it can be set from the 'Tab' menu.
                I believe you can do that per game from the 'Tab' menu, but you can set it manually by using the following as an example:
                bzone/display_flicker 30
                That will set the flicker value to 30 for just 'Battle Zone'.
                • caver01C
                  caver01 @FlightRisk
                  Unfortunately, we don’t have phosphor or bloom effects in AdvanceMAME. Also, none of the vector settings are accessible through the GUI menus. You have to edit the .rc config file. This post covers the details.
