    Analog Input Help
    inputanalog
    1 Posts 1 Posters 449 Views
    • AlturisA
      Alturis
      From what I have read about input configs it seems like setting up analog control should not be too difficult.
      I have just one joypad hooked up as js0 which is an Xbox 360 wireless.
      I ran jstest /dev/input/js0 and confirmed that the left stick x/y is analog axes 0 and 1, and the right stick is axes 2 and 3.
      Within a particular game's cfg file (roms/arcade/spyhunt.zip.cfg) I have what I think should be the analog bindings enabled. (from reading the default retroarch.cfg)
      input_player1_l_x_plus = +0
      input_player1_l_x_minus = -0
      input_player1_l_y_plus = -1
      input_player1_l_y_minus = +1
      I am using AdvMame to emulate this rom and trying to use the in-game menus to bind an analog axis to the pedal and steering wheel. But thus far I have never been able to get it to detect analog input.
      I was pursuing some other solutions previously that involved the use of xboxdrv but it seems like if I have a joystick that is already correctly sending analog info I should just be able to bind that without too much complexity.
      RP 4.7.1 • Pi4 4Gig • CanaKit Aluminum • 64GB microSD • 1920x1080 BarTop [2 Sanwa sticks]
