    All ROMs running in slow-mo
    ubuntu 16.04slowlag
    4 Posts 3 Posters 1.9k Views
    • F
      FattySparks
      Hey everyone!
      I have just installed the latest version of RetroPie (4.3.11) on an old computer running Ubuntu 16.04 64-bit. I just put a new SSD in the computer and freshly installed everything tonight. Every game that I try to play is running in slow motion (both video and sound).
      Here are some PC specs:
      Processor: AMD Phenom 9100e Quad-Core Processor 1.8 GHz
      Graphics: AMD RS780 (Radeon 3200 On-board Graphics card)
      RAM: 4 GB DDR2 PC2-6400
      Hard Drive: 120 GB SSD
      I've tried enabling/disabling the following settings in RetroArch as recommended in other posts that I've found:
      Threaded Video
      Vertical Sync (VSync)
      Hard GPU Sync
      None of it has helped. I know the PC is old, but I would think that it should be better than an RPi.
      Is it my PC, or am I missing something?
      TYIA
        Sounds like a slow video driver problem. Are you using the default driver (amdgpu) or the AMD (fglrx) driver ?
        • fabio78F
          fabio78
          Make sure you’re not running European PAL ROMs.
          • F
            FattySparks @mitu
            @mitu said in All ROMs running in slow-mo:
            I've tried to install the AMD driver but it gives me the following error:
            One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver. Optionially, run the installer with --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended. See /usr/shar/ati/fglrx-install.log for more details.
            Here's the log:
            Check if system has the tools required for installation. fglrx installation requires that the system have kernel headers. /lib/modules/4.13.0-32-generic/build/include/linux/version.h cannot be found on this system. One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver. Optionally, run the installer with --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended.
