    Running Roms Directly From USB HD (4TB) Not Showing In RP
    usb driveretropiecfgemulationstaionexternal hdd
    2 Posts 2 Posters 687 Views
    • L
      lordkramGB
      I'm hoping someone can help me out here i'm starting to pull my hair out figuring out whats wrong
      So I know to start windows can only format a 2TB Drive max for FAT32, so I formatted to NTFS.
      Created the retropie-mount folder, enabled the rom script in RP and it successfully copied over the required structure to the USB drive
      Problem i'm having is I have added new games onto the USB drive, but RP will not see them after rebooting
      I have tried changing the rom paths in /etc/emulationstation/es_systems.cfg, to point towards the usb drive but that resulted in getting the "ES cannot find any systems" error, so I just wiped the sd card and started again
      What am I doing wrong, or what else do I have to change to get RP to recognise the roms located on my USB?
      I read some info about where a different cfg file RP uses (Not ES) but was confusing as hell!
        dankcushions Global Moderator @lordkramGB
        @lordkramgb please fill out https://retropie.org.uk/forum/topic/3/read-this-first
