    Controllers work on RetroPie but not ROMS
    controller
    4 Posts 3 Posters 593 Views
      rpretropie
      I'm having difficulty configuring controllers to work with various ROMs (I've only tried NES up to this point). I'm using PS4 dualshock controllers that have been configured and work perfectly on the RetroPie menu and set up screens. ROMs load fine, I can see gameplay and select some buttons, but most buttons aren't mapping as configured. For example, the B button (mapped to X) re-sets the game. The START button (mapped to options) backs out to the menu. The A button (mapped to O) does work correctly. I've tried different emulators at start up but the result is the same. I've also tested ROMs on another SD card build (compiled from someone with much better skill level) and they work just fine. Everything I'm using is the most up-to-date available. Any help is appreciated.
        mitu Global Moderator @rpretropie
        @rpretropie Your problem sounds like you always have the Hotkey active. What did you choose for 'Hotkey' when you configured the controller ?
        I'd advise to re-configure your controller and skip the Hotkey button mapping, then choose Yes when asked if you want to use the Select key as Hotkey.
        R cyperghostC 2 Replies Last reply Reply Quote 1
          rpretropie @mitu
          @mitu Thanks your reco was spot on! Working now.
            cyperghost @mitu
            @mitu I would you give +5 for this if I could!
