    Daphne . Arcade joystick orientation wrong.
    daphnedaphne controll
    164 Posts 28 Posters 52.1k Views
      shift
      @grant2258 said in Daphne . Arcade joystick orientation wrong.:
      The dragon rise controller is in analog mode by default not digital. Im not sure what your saying here are you using a digital only controller encoder or a dragon rise?
      First of all, thanks for the reply. I am using an Arcade Stick mapped to a Dragonrise encoder. I think the "problem" is here: src/io/ input.cpp because I understand that only the first 10 keys are mapped, that is from [1] to [10]. Unfortunately many controllers, even if they have less than 10 keys, the first 10 are not necessarily mapped, in fact, in my case, even if I only have 8 keys, if I use jstest the buttons are: 0, 1, 6, 7, 8, 9, 10, 11 which are then translated by the daphne into: 1, 2, 7, 8, 9, 10, 11, 12. Here, buttons 11 and 12 are not considered absolutations from the dapinput.ini file. If you could modify the package to ensure that the system can see at least 12 keys it would be possible to map the controllers that use the dragonrise encoder.
        grant2258 Banned
        Well the standalone package has mapping issues I did fix that and it works for the dragon rise on my repo. Like I said before the dragon rise defaults to analog mode and daphne directions work fine. The 10 buttons is plent to map the rest of the keys
          shift
          The analog stick (which was the main problem) with your package works very well. But, as I said, the buttons are correctly mapped up to the number 10, with this I mean that even if I have 8 buttons to map, but 2 of them are seen by jstest as button11 and button12, in the dapinput.ini file, the latter two buttons are not even considered and therefore cannot be mapped.
            grant2258 Banned
            Thats not how its works do you have 18 entries in your dinput file ? you pick the button you want to use in the dinput if you do need more than ten let me know.
            edit added up to 18 buttons on the repo for you. I dont see why anyone would set them all on there controller but its done. Just add any extra button defines to your dainput.(youll need to recompile though)
            "KEY_UP", "KEY_LEFT", "KEY_DOWN", "KEY_RIGHT", "KEY_START1", "KEY_START2", "KEY_BUTTON1",
            "KEY_BUTTON2", "KEY_BUTTON3", "KEY_COIN1", "KEY_COIN2", "KEY_SKILL1", "KEY_SKILL2",
            "KEY_SKILL3", "KEY_SERVICE", "KEY_TEST", "KEY_RESET", "KEY_SCREENSHOT", "KEY_QUIT", "KEY_PAUSE",
            "KEY_CONSOLE", "KEY_TILT"
            is all the button names that can be set currently any 10 can be changed it changed to 18 for you now. I did at one point change the joystick buttons to match the joystick number but had to put it back the way it was for the retropie script that creates the input file
            • _robert1243_
              _robert1243
              I had that with the exact same controller.
              I'd try switching the connectors around to the expected orientation. That worked for me.
                superdan
                Hi all!
                My situation with original Daphne RetropPie setup
                Joy directions wrong ( i die even if the movement is correct)
                Button 1 Correct
                So.
                @grant2258 i followed these steps:
                1 unistalled Daphne at all
                2 sudo nano pico /home/pi/RetroPie-Setup/scriptmodules/emulators/daphne.sh
                3 replaced RetroPie with grant2258 ( gitPullOrClone "$md_build" https://github.com/grant2258/daphne-emu.git retropie )
                4 Re-Installed Daphnefrom source
                My dapinput.ini is
                # Daphne cutom keyboard and joystick mapping
                # Each input is mapped to 2 keyboard keys and one joystick button.
                # A joystick's first analog stick is also automatically mapped.
                # The first two numbers are SDL keyboard codes (or 0 for "none")
                # Find keyboard codes here:
                # http://www.daphne-emu.com/mediawiki/index.php/KeyList
                # The third number is the joystick button code (or 0 for "none")
                # Since 0 is reserved for special meaning, joystick button 0 is identified
                # as 1 here.  Button 1 is identified as 2, and so on.
                # Find the button you want to map by running:
                # jstest /dev/input/js0
                [KEYBOARD]
                KEY_UP = 273 114 24
                KEY_DOWN = 274 102 24
                KEY_LEFT = 276 100 24
                KEY_RIGHT = 275 103 24
                KEY_BUTTON1 = 306 97 24
                KEY_BUTTON2 = 308 115 24
                KEY_BUTTON3 = 32 113 joy start
                KEY_START1 = 49 0 10 42
                KEY_START2 = 50 0 42
                KEY_COIN1 = 53 0 joy coin
                KEY_COIN2 = 54 0 joy quit
                KEY_SKILL1 = 304 119 joy pause
                KEY_SKILL2 = 122 105 joy button1
                KEY_SKILL3 = 120 107 joy button2
                KEY_SERVICE = 57 0 joy button3
                KEY_TEST = 283 0 joy console
                KEY_RESET = 284 0 24
                KEY_SCREENSHOT = 293 0 24
                KEY_QUIT = 27 113 24
                END
                Now Joystick movements work like a charm BUT
                i lost my BUTTON 1 on my joystick
                so no action button at all
                My controller is seen as a general usb joystick.
                Any help?
                Thanks all
                  grant2258 Banned
                  KEY_BUTTON1 = 306 97 1
                  KEY_BUTTON3 = 32 113 3
                  you will need to use jstest (add one to the value) for what button numbers you want to use for the function
                    superdan
                    @superdan said in Daphne . Arcade joystick orientation wrong.:
                    grant2258
                    GOT IT!
                    Thanks @grant2258 !!!!
                    • Z
                      zack06007
                      Hello, I tried to understand the subject but I also have a left / right inversion. I was on retropie and I just changed to dragon's lair but with Batocera I have the same thing! I am new to trying to understand but what must be done to reverse orders. On my terminal (sticker: Dragon's lair) this is the only game I really want and I have been looking for weeks. I'm ready to cut the wires to reverse the order, that's to say Who can help me I will be grateful. thank you
                      https://zupimages.net/up/20/22/i7mz.png
                      For information my arcade machine: https://www.buzz-arcade.com/544-large_default/kit-stickers-borne.jpg
                        shift @grant2258
                        @grant2258 I forgot to thank you. Now it works perfectly! Thanks again!
                        • KrakatoaK
                          Krakatoa
                          Joystick works perfect, but I can only get the coin button to work. This is my daphne.ini. Any tips?
                          [KEYBOARD]
                          KEY_UP = 273 114 24
                          KEY_BUTTON1 = 306 97 5
                          KEY_BUTTON2 = 308 115 6
                          KEY_BUTTON3 = 32 113 7
                          KEY_COIN1 = 53 0 8
                          KEY_COIN2 = 54 0 0
                          KEY_SKILL1 = 304 119 0
                          KEY_SKILL2 = 122 105 0
                          KEY_SKILL3 = 120 107 0
                          KEY_SERVICE = 57 0 0
                          KEY_TEST = 283 0 0
                          END
                            tagnetti @beamquaker
                            @beamquaker I am having the exact same issue on the exact same stick. It’s driving me mad been about 3 hours messing with this. Buttons no worries but the stick seems to work for only certain directions. Or I really suck worse than I thought at the game 😬
                              Clyde @tagnetti
                              @tagnetti Does this happen only in Daphne or also in Emulation Station and other emulators?
                              If the latter and you have manually wired arcade joysticks, check the wiring. It has to be exactly the same for both sticks.
                              Besides that, you can check your joysticks in RetroPie's command console with the jstest command. For example:
                              jstest /dev/js0
                              Replace the 0 with the joystick index of the stick you want to test. You can press the tab key two times quickly in succession after the js to get a list of all existing joystick numbers. Press Ctrl+c to stop the test, and enter exit to leave the console.
                                tagnetti @Clyde
                                @clyde Thankyou. The problem only exists in Daphne. Everything else is perfect. It’s weird as when I try certain titles in Daphne it’s almost like left and right work like a button press left and right but don’t sustain any movement like moving a ship for example. Can’t wrap my mind around what could be causing that issue.
                                  Clyde
                                  @tagnetti I don't know if I misunderstand you, but as far as I know Daphne games (Dragon's Lair I + II and Space Ace), the player is expected to "tap" the stick in the right moment and direction, but not keep it for long in one direction. Maybe that's the problem?
                                  Other than that, did you check Daphne's controls in the dainput.ini? See https://retropie.org.uk/docs/Daphne/#controls
                                  AshpoolA 1 Reply Last reply Reply Quote 0
                                  • AshpoolA
                                    Ashpool @Clyde
                                    @clyde You're right for those games... but for others, like "astron belt", you are moving a sprite overlaying the laserdiscs video. So @tagnetti, we may need the info about what "certain titles" are meant...
                                      dabbler
                                      Apologies for dragging an old thread up. I came across this while searching for solutions to my DragonRise not working in Daphne.
                                      Thanks to @grant2258 , using your modified/fixed daphne - the controls work just fine - super.
                                      However, it appears Daphne has recently been updated (Retro pie source) by @pjft to support :
                                      Badlands
                                      Begas Battle
                                      Road Blaster
                                      So Ive moved to the offical source build, and of cource, my controls stop working. Would be great to have the best of both worlds, will @grant2258 's changes ever be included in the official source, or could the latest offical source be modified to inlucde these must have changes?
                                      Many thanks for all your help and to all those involved
                                        pjft @dabbler
                                        @dabbler you may try to compile and install it from my RetroPie branch, that I used to develop those changes while keeping Grant's control patches:
                                        https://github.com/pjft/daphne-emu/commits/retropie
                                        Probably the easiest way is to edit the Daphne RetroPie Setup script to retrieve the code from my repository and branch, and compile from source.
                                        I could consider pushing it upstream to RetroPie but I'm always hesitant of doing so with other people's code (in the case, Grant's changes), out of consideration for their authorship but he is unlikely to do so on his own by now...
                                        Note taken. Thanks and a happy new year.
                                          dabbler @pjft
                                          @pjft said in Daphne . Arcade joystick orientation wrong.:
                                          Thanks, sounds like a good plan - my linux knowledge is lacking, im doing the following:
                                          cd /home/pi/RetroPie-Setup/
                                          sudo ./retropie_packages.sh daphne clean
                                          sudo git clone https://github.com/pjft/daphne-emu/ tmp/build/daphne
                                          sudo ./retropie_packages.sh daphne depends
                                          sudo ./retropie_packages.sh daphne build
                                          sudo ./retropie_packages.sh daphne install
                                          sudo ./retropie_packages.sh daphne configure
                                          However it fails on the install line (.bin not found), are you able to help please?
                                          Thanks so much!
                                            pjft @dabbler
                                            @dabbler Well, that's already quite more than what I'd expect from someone lacking Linux knowledge :D
                                            I believe that you'd need to check out the "retropie" branch on my end, so:
                                            cd tmp/build/daphne
                                            sudo git checkout retropie
                                            and then the rest.
