    When in emulation, some hot-keys (or keys in general) no longer work
    rguihotkeysinput issue
    2 Posts 1 Posters 516 Views
    • Nathan1031982N
      Nathan1031982
      It's weird as some hotkeys no longer work at all.
      For instance, I can use hot keys to cycle through shaders, but can't actually exit the emulation or open the RGUI config.
      Sometimes pressing A and B together cause the emulation to exit, other times it doesn't.
      It doesn't matter what emulator I am in, and I have now tried updating everything, clearing input-configurations (through RetroPie setup and all configurations per each system), and nothing has fixed this.
      I first noticed when I loaded a PAL rom and had to get into the RGUI to configure it for PAL so it ran properly as having (E) in the file name didn't automatically detect that.
      I have multiple controllers that I will use, connecting them only as needed. Outside of emulation, everything works perfectly.
      • Nathan1031982N
        Nathan1031982
        Never mind. Found out it's the recent update to RetroArch causing the issue. Re-installing the image without updating fixes the issue.
