lr-mame2003 TATE mode rotation direction?
  • Hi All,
    First off want to thank the community and developers. Hats off, as Retropie is Da Bomb! Love Love Love it.
    Pi Model: 3
    Power Supply used: CanaKit PS
    RetroPie Version Used 4.3, 4.3.12 script.
    Built From: Retropie 4.3 image.
    USB Devices connected: Keyboard, TurboTwist2 Optiwiz, PS4 USB Controller
    Controller used: Custom Arkanoid Controller, PS4 Bluetooth & USB
    Emulator: lr-mame2003
    How to replicate the problem: I have an older Dell 5:4 LCD monitor, and like to manually rotate it for vertical arcade games. I've been testing lr-mame2003 TATE mode and love it, but have a little issue.
    When playing Arkanoid, TATE mode enabled, my picture rotates correctly 90 degrees counterclockwise. This allows me to rotate my screen to the right/clockwise and start playing. I've tested a few other games, Qbert is one, the game pitcutre rotates 90 degrees clockwise instead. My monitor only allows rotation clockwise 90 degrees.
    I posted this same issue to the libretro forum, but was wondering if anyone else ran into this, or knows of a way to force TATE mode to always rotate in one direction.
    Thanks much for any feedback!
    Robo
  • Global Moderator
    @robotronman said in lr-mame2003 TATE mode rotation direction?:
    unfortunately the way it's working is just mimicking the way that the original hardware rotates the monitor. i can see a possibility of 'inverting' this in the code via an extra option in the tate core option - you should log an issue here and tag me in it :) https://github.com/libretro/mame2003-libretro/issues
  • Global Moderator
    actually, thinking about it you could achieve much the same effect by forcing a per-game rotate yourself, i think?
    still with tate mode on, create a qbert.zip.cfg file, and in that put this line:
    video_rotation = 2
    then start the game. please let me know if that works!
  • @dankcushions thanks! I’ll give this a shot in the morning and let you know.
    Thanks for the tip :)
    Robo
  • @dankcushions works perfectly. Thanks for the fix :)
    This configuration is awesome for anyone that has a manually rotatable monitor and wants all their vertical games to automatically and consistently rotate for vertical gaming fun in lr-mame2003!
    Here is an example per-game configuration file just to show the settings I like best!
    I place all my core per-game overrides in this location:
    /opt/retropie/configs/all/retroarch/config/MAME 2003/<gamename>.cfg
    example arkanoid.cfg
    video_allow_rotate = "false"
    video_rotation = 0
    video_scale_integer = "false"
    video_shader_enable = "true"
    video_shader = "/opt/retropie/configs/all/retroarch/shaders/zfast_crt_standard_vertical.glslp"
    example qbert.cfg
    video_rotation = 2
  • @dankcushions said in lr-mame2003 TATE mode rotation direction?:
    video_rotation = 2
    It doesn't work for me even if I input different numbers from 0 to 3. Also, I don't have the MAME 2003, so I made a new folder. I did the same naming convention—i.e., ddonpchj.zip.cfg with video_allow_rotate = "false"
  • Global Moderator
    @edwardthehuman said in lr-mame2003 TATE mode rotation direction?:
    ddonpchj
    doesn't run on mame2003, so you're not using mame2003.
