Mega Drive sound problem
An issue with sound with Sega Mega Drive. The Stereo sound is wrong \ unstable, as if some sounds \ samples were missing. When you switch the sound in Mono mode in the game Contra Hard Corps, this problem disappears.
So how to fix this problem, or I should keep switching it into Mono? -
@shirion which emulator are you using? Have your tried switching emmulators?
@quicksilver yes, no results
Switching between emulators and having the same (strange) problem, indicates a hardware issue. Are you using the analogue jack output or HDMI for sound?
@shirion have you tested multiple games? Are they all having this issue? Which region ROMs are you using?
