    audio issues with SNES in pi3
    snes superninnintendo snes
    48 Posts 5 Posters 11.9k Views
    • DarksaviorD
      Darksavior @lovelorn88
      @lovelorn88 Start over with the official retropie image. It's how I usually troubleshoot my problems, and slowly start changing stuff until my problems start. Don't alter a thing but controller settings and add yoshi's island to test in 2005/2010/snes9x and add a normal snes game like smw and test that too.
      lovelorn88L 2 Replies Last reply Reply Quote 1
      • lovelorn88L
        lovelorn88 @Darksavior
        @darksavior alright... yeah im actually gonna go to the store in a bit and pick up another 64gb sd card and flash retropie on there and if it STILL acts up then it has to be the board itself ima throw starfox and yoshis island
        thelostsoulT 1 Reply Last reply Reply Quote 0
        • lovelorn88L
          @darksavior maybe something bad happen while downloading? and flashing? hmmm idk
          • DarksaviorD
            @lovelorn88 Well, for me, I recently started over clean but only transferred my gamelist.xml and scraped images over. Before, I used to transfer everything in my configs folder, and that was causing pegasus, the frontend I'm using, to crash for some weird reason after exiting reicast. That's a learning experience for me.
            • thelostsoulT
              thelostsoul @lovelorn88
              @lovelorn88 I remember someone had issues with fx chip games too. i can't remember what it was exactly, but the common between these games is the fx chip. And there was a setting he just turned on or off in snes emulator and then it worked. Here this was the thread: https://retropie.org.uk/forum/topic/16902/loading-state-on-lr-snes9x2010-on-yoshi-s-island
              It was about save states. Looks like fx chip games do a lot of problems. My Stunt Race FX menu is glitchy too.
              • DarksaviorD
                Darksavior @thelostsoul
                @thelostsoul I dug out my pi3 and installed the retropie stretch image to another microsd. Fully updated, nothing touched but res to 1080p and setup wifi/pad, stock speeds trying yoshi's island:
                lr-snes9x: It started out fullspeed in level 1-1 but it will have dips to 58fps and a bigger dip to 56fps in other sections where the audio will start to skip. Not sure if an overclock to 1300 might help. This pi no longer has any cooling so I'm not trying it:)
                lr-snes9x-2010: Fullspeed in the sections where there was skipping in lr-snes9x.
                thelostsoulT lovelorn88L 2 Replies Last reply Reply Quote 0
                • thelostsoulT
                  thelostsoul @Darksavior
                  This post is deleted!
                  • thelostsoulT
                    thelostsoul
                    I just tested Starfox and get crackling sound in intro of game and of first stage intro. Its just a little bit. One question, do you use audio from HDMI? I use the audio jack, because my monitor don't have built in speaker. Also, look at this site: https://retropie.org.uk/docs/Sound-Issues/
                    lovelorn88L DarksaviorD 2 Replies Last reply Reply Quote 0
                    • lovelorn88L
                      @darksavior ok.. heres the thing.. i just got back from the store with my NEW SanDisk 64gb class 10 sd card..... put retro pie on there and just a few snes games and the problem is STILL there....... audio cuts in and out, gets laggy, stutters not just FX games Batman returns for example does this to this is on a PI3 model B ....so i dont know, its not the tv because i even tried with headphones and the issue is still there..... lol wasted $30 hahaha damn...... only thing i could think now is my board is bad??? but then again it would only effect snes..... ill add the audio issues are not constant its random
                      • lovelorn88L
                        lovelorn88 @thelostsoul
                        @thelostsoul try Yoshis island and dont just wait 1 min its VERY random Batman Returns is another one that has lots of crackling oh and Demons Crest i dont have any of these problems with the snes mini on my HDTV and i use a soundbar.... but i have tested out the tv speakers and even plugged headphones into the pi itself.... sometimes the audio is worse then others
                        • DarksaviorD
                          @thelostsoul Yes, I use hdmi only. I know the jack might cause some distortion, but I don't believe @lovelorn88 has this problem. The distortion would be nonstop.
                          @lovelorn88 You never said if you're using a 3rd party image or not. I don't believe the pi's broken. I still suggest you start over with the stretch image https://retropie.org.uk/forum/topic/16307/retropie-4-3-15-stretch-images-for-testing
                          • lovelorn88L
                            @darksavior i JUST started over with a new image from retropies site those.........
                            • lovelorn88L
                              @darksavior and what do you mean by a 3rd party image i went to retropies site.... downloaded retropie... flashed it to my sd card.... and just now throw a few snes games on it.... the audio stuttering is still present all my other systems on my pi run just fine though..... my only guess is now its the reaspberry pi i have its self but that doesnt explain why my other systems run great and not snes
                              • thelostsoulT
                                @lovelorn88 said in audio issues with SNES in pi3:
                                I am running it currently. Everything seems perfect. Sorry, but I can't replicate your problem.
                                Btw, my Starfox problem is solved. I had to disable Rewind function and now the crackling is gone. Damn that function gave me a headache on Mame too... Never use Rewind!
                                Maybe there is something with timing issue with the tv or hdmi? Mind changing the HDMI cable? Or if you can, try a different tv. Maybe try audio jack (you have to tell RetroPie to use audio jack btw), just to eliminate these hardware problems and if it is emulation side. Maybe set on or off V-Sync. What else could it be?
                                Or the roms are bad. Try to get roms with exclamation mark [!] in filename, becaus those are generally good dumps.
                                • lovelorn88L
                                  @thelostsoul how many diferent tvs should i try? LOL and hmdis? LOL ive tried 2 different tvs and 2 different hdmis..... and like i said i EVEN redownloaded retropie on another SD..... only thing i didnt do was get A different pi.... are you using Pi3B??? doesnt make anysense why im the only one with this problem... yes yes yes... i tried different roms..... Ive spent HOOOUURRRSSS on this no joke.....
                                  • lovelorn88L
                                    @thelostsoul a vew 32x games do this to... but its a bit different... sounds more of a glitchy sound Metal head on the sega 32x was one of them... but ive never played a 32x before nes is perfect... turbografx and the CD add-on run great hell even ps1 some games on the ps1 i can use the high res mode and it runs fine......
                                    • DarksaviorD
                                      @lovelorn88 I'm about stumped. Only option left is to try another ac adapter. If yours has a switch on it, or if it's not 2.5a, it might be the cause. Phone chargers are not recommended and will cause voltage drops.
                                      lovelorn88L 3 Replies Last reply Reply Quote 1
                                      • lovelorn88L
                                        @darksavior Ive gone through 2 different power supplys.... first was one that FRYs sold me its from RHINO it was a 5v 2.5a and it would bring the lighting bolt up very often so someone recommended me a 5v 3a power supply and yes this one has a on/off button button but i nolonger have the lighting bolt
                                        • lovelorn88L
                                          @darksavior LOL as I said in the post for this thread u highly doubt anyone will figure out what the issue is..... its to the point now where everyone is pretty mush like HEY did you try this, what about this, hold it high in the air while playing? LMAO i have no clue what it is..... maybe the pi just doesnt like me.... the only thing i have NOT changed hout was the pi itself....... thats really it....
                                          • thelostsoulT
                                            thelostsoul
                                            Did you try out the settings at the site link I gave you?
                                            On PSX I had similar issues with crackling sound and the driver change helped a lot. Try to change at /etc/retroarch.cfg or if available in RetroArch menu (hotkey + X):
                                            audio_out_rate=44100
                                            audio_driver=sdl
                                            From that page, here a quote:
                                            "I managed to get perfect sound with retroarch+ lr-snes9x2002 core by defining sdl as the audio backend with 44100 samplerate."
                                            You don't need to use older emulator. I just wanted say these settings might help.
                                            lovelorn88L 1 Reply Last reply Reply Quote 1
