    Need some help exiting retropie.
    exit emulator
    4 Posts 3 Posters 1.9k Views
      GuiGuiBerto
      I'm new to raspberry pi (just set it up yesterday) and i downloaded retropie and installed some roms to play. i played a bit and decided i wanted to go back to the desktop. well after searching around on google a bit i followed some instructions to get back to the desktop but they didnt work. My current situation is that I've disabled the splash text from boot up on the pi and when i power it on i get the "pi@retropie" command line screen. In the retropie settings i tried to switch the auto startup settings to boot it automatically to desktop but it says that i need to install 'sudo apt-get start lightdm' but when i type that into the command line nothing happens. If you could answer my question and also tell me how to get back to retropie after getting to the desktop it would be greatly appreciated.
      Pi Model 3B
      Retropie version 4.3
      • V
        Vodkanakas
        When exiting Desktop your sent to terminal? if thats the case input
        emulationstation
        that should get you back into retropie
          GuiGuiBerto @Vodkanakas
          @vodkanakas i know the emulation station command to get back into retropie but I'm not sure how to get to my desktop. I'm stuck at the command terminal and startx and other commands won't work for me.
            mitu Global Moderator @GuiGuiBerto
            @guiguiberto Follow the docs on how to install it first, the RetroPie image does not have it included
            • Install the Pixel desktop environment - https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go
            • How to configure which one is started first - https://retropie.org.uk/docs/FAQ/#how-do-i-boot-to-the-desktop-or-kodi
