    EmulationStation Grid View v1 ready for wider testing
    emulationstatiogrid
    63 Posts 9 Posters 21.7k Views
      jdrassa
      @A12C4 has been putting a lot of work in over the last few months and v1 of the grid view for ES is now available for testing in the emulationstation-dev module in RetroPie-Setup. It would be great to get as much feedback as possible from users and theme creators.
      The theme documentation has been updated. As the grid view continues to evolve some things may change though.
      Get latest build of EmulationStation for Windows here
      ruckageR 1 Reply Last reply Reply Quote 3
        cloudlink
        What themes are compatible with grid view?
        A12C4A 1 Reply Last reply Reply Quote 0
          Material Theme & Modern TV, both made by me.
          Not aware of any else
          • ruckageR
            ruckage
            Great news, will be getting my themes updated to support it hopefully by next weekend.
            Big thank you to @A12C4
            • A12C4A
              A12C4 @cloudlink
              @cloudlink There is 3 themes I modified for testing : a modified version of the classic carbon theme and a update for new theming syntax of @lilbud 's material and moderntv themes. You can find the links below :
              • Carbon
              • Material
              • Moderntv
              Grid view wiki
                lilbud @A12C4
                @a12c4 wanna send a PR to my branch?
                • A12C4A
                  A12C4 @lilbud
                  @lilbud It's not complete, I half added the "custom collection", and I was too lazy to change all the system specific theme.xml so the color of the selector is based on the system color :)
                  You can find my changes here :
                  • for material theme
                  • for morderntv theme
                  Grid view wiki
                    cloudlink
                    I just installed emulationstation-dev from source. I also installed the new Carbon theme. In ES, when I sect the Carbon theme and Grid gamelist view style, then click Back, it just freezes and I have to reboot.
                    Am I missing a step?
                    • A12C4A
                      A12C4 @cloudlink
                      Hello @cloudlink , I'm sad to hear that you have troubles enabling the grid view.
                      What is your system running ES ? Can you detail a bit more what you are doing step by step (are you changing both the game list view style and the theme at the same time for example ?)
                      I am unable to completly reproduce your problem. When I switch theme and game list view style to the grid view on my pi 3B, it freeze for about 4~5 seconds but after that it work perfectly.
                      Grid view wiki
                        cloudlink @A12C4
                        @a12c4
                        Thanks for the reply.
                        Sorry, I should have included more detail.
                        I'm running the latest version of Retropie, upgraded from the latest official image, on a Raspberry Pi 3 B+.
                        The only custom changes I've made that I can think of that might interfere are a few emulator entries I manually added to es_systems.cfg. Those are unthemed right now as I'm using the new version of Carbon with no customizations.
                        Could that cause an issue?
                        I've tried changing to the Carbon theme first then enabling the grid view. It changes to the Carbon theme just fine, but freezes indefinitely when changing to grid view.
                          jdrassa
                          @A12C4 I updated my main Pi which has a lot more games on it and saw the same hanging. I did some testing and traced the delay back to here. I believe at one point you explored having the ImageGridData holding the image path vs. a TextureResource. At a minimum we probably need a way to defer the creation of the TextureResource until they are first needed.
                          • A12C4A
                            A12C4 @jdrassa
                            @jdrassa Define "first needed".
                            Yes I explored instantiating the TextureResource while navigating in the grid and it gave really poor results, with huge fps drops.
                            Another solution could be to instantiate them only for the currently selected system, but that way you may experience big loading time if you switch to a system with a lot of games for the first time.
                            This 9000+ games collection ain't gonna get loaded by itself.
                            Grid view wiki
                              jdrassa
                              @a12c4 said in EmulationStation Grid View v1 ready for wider testing:
                              Not entirely sure. My first thought was to load only the textures needed to fill the grid tiles and then load more as they are needed, maybe with some sort of predictive loading ahead based on scroll direction/speed. I assume that is along the lines of what you already tried.
                              After thinking about it further, it may be that the check for for file existence that happens before loading the texture may be contributing to the delay. I know that the auto-discovery of images was disabled on the stable branch due to the delay checking for the image existence was causing.
                              • A12C4A
                                A12C4 @jdrassa
                                @jdrassa Sorry for the late answer, I had some troubles with my computer that I needed to fix first.
                                So, after taking a look with callgrind, it look like the check for file existence have nearly no cost compared on the TextureResource instantiation. (btw if you have a better method than using callgrind to profile C++ code, I'm interested, as it's far from perfect and I would like to focus on the grid optimization along with debug in the next weeks).
                                I think we have 2 bottlenecks here : the TextureRessource instantiation and the TextureData loading.
                                The 2nd one can be easily delayed by loading only texturedata for the selected system instead of all system at the same time. This is actually something that I had already made in the first version of the "dynamic image loader" feature but didn't reimplemented when I restarted the final version from scratch.
                                I think this should help a lot here : Since the modified carbon theme that I shared display 15 grid tiles per system, this mean ES will load up to 15 texture per system (ofc it will load only 2 if you have only 2 games for a system), so if you have let's say a 30 system game collection, ES will load up to 15*30=450 texture at the same time, thus hanging a little bit ... With that modification, ES will only load the texture for the selected system, so if you change system using left/right shoulder button, it will take a little more time to load, but it should completely solve our problem with big game collections.
                                Grid view wiki
                                • ruckageR
                                  ruckage @jdrassa
                                  @jdrassa
                                  Hi, is there an up to date version for windows that matches the raspberry pi as the version currently on your continuous build doesn't seem to be working correctly, setting the grid to <scrollDirection>horizontal</scrollDirection> results in no grid being displayed and if you try to activate grid through the menu or change the theme ES crashes.
                                  Thanks in advance for your help.
                                  • A12C4A
                                    A12C4 @ruckage
                                    @ruckage Hi, I'm aware of this 2 issues and working on a fix for both of them. This is taking a bit longer than expected, as I said in the comment right above yours. Once both fixes are released, jrassa should come with a new version anytime soon. Thanks for your patience.
                                    Grid view wiki
                                    • ruckageR
                                      ruckage @A12C4
                                      @a12c4
                                      No problem, thanks for the reply and for your continued work. I've been working on some mock-ups for the grid that I'll be adding to my themes you can see them here if you're interested.
                                      Thanks again.
                                        Hmmm....
                                        • A12C4A
                                          A12C4 @lilbud
                                          @lilbud Can you give some context to this image ? Are you reporting a bug or do you just want to show your last creation ?
                                          Grid view wiki
                                            lilbud @A12C4
                                            @a12c4 yes
                                            Showing off a mockup I've been working on
