    TriggerHappy Daemon (THD) doesn't work on my Pi running Retropie ! Help
    retropietriggerhappydaemonhelpbug
    32 Posts 4 Posters 9.2k Views
      mitu Global Moderator @Djon
      @djon Does the process shows up when your run ps -ef from the terminal ?
      EDIT: Yes, of course you need to add it before the exit, otherwise it's not executed.
        Djon
        Ok so i add it before "exit 0" this time and run ps -ef @mitu
        And i think the line you're interested in is
        "nobody 364 1 0 03:26 ? 00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*"
          @djon Doesn't seem to be correct. Have you disabled the service ? The process shown there seems the one started from the built-in service script. Post your rc.local file contents, surrounded by code tags (```).
            Djon
            No prob ! @mitu
            # rc.local
            # This script is executed at the end of each multiuser runlevel.
            # Make sure that the script will "exit 0" on success or any other
            # value on error.
            # In order to enable or disable this script just change the execution
            # bits.
            # By default this script does nothing.
            # Print the IP address
            _IP=$(hostname -I) || true
            if [ "$_IP" ]; then
              printf "My IP address is %s\n" "$_IP"
            fi
            /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --devicelob /dev/input/event* &
            exit 0
              @djon Just change it to
              # Start THD as user pi
              nohup /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --user pi --deviceglob /dev/input/event* &
              exit 0
              and reboot. Disable the service with sudo systemctl disable triggerhappy first.
                Djon
                I'll do it in a sec, so i'll change all the file just with these lines ? @mitu
                  Djon
                  Okay so i made the mistake to erase all the file, to put just your line...
                  So i did it again, with just your line at the end, and i can say... that... it is workinggggggggggg !!!!!!! @mitu
                  I think that i will start again from stratch with a brand new retropie image, next time i'll just need to put :
                  exit 0
                  Or i'll need to take all the steps we made ?
                    Djon
                    Since you're here @mitu and that your the best guy ever, i need to change a bit the script to make the brightness increase by 25% each time, i was thinking :
                    sudo chmod 777 /sys/class/backlight/rpi_backlight/brightness && echo 25% > /sys/class/backlight/rpi_backlight/brightness
                    ... hum no i just test it and they say "invalid argument"
                    FYI the brightness can go from 0 to 250
                    • H
                      Headrush69
                      I ran into the same issue trying to get triggerhappy to process the VOLUME_UP and VOLUME_DOWN events from my Dell AC511 soundbar.
                      No matter whether I set the user to run the process as in /etc/defaults/triggerhappy, or /etc/init.d/triggerhappy, it would always run as user nobody.
                      The process would run, but because nobody doesn't have privileges, my commands to amixer would not run.
                      The solution I found was to edit /etc/systemd/system/multi-user.target.wants/triggerhappy.service and set the user in there to pi.
                      After doing that and restarting the daemon, the triggerhappy process ran under user pi and everything worked.
                      Edit: Future updates my overwrite changes to this file, I don't know.
                        simple @Headrush69
                        @headrush69 Thank you sssssssssssssooooooooooooooooooo much headrush!
                        I have spent the last 2 days digging for this!!
                        My volume knob, It WORKS!
                        I literally created an account here just to thank you!
                        • mituM mitu referenced this topic on
                        • L levis78 referenced this topic on
