    need help getting after glow xbox one wired controller to work on retropie
    controller
    27 Posts 4 Posters 5.2k Views
    • cynitalC
      cynital
      Pi Model or other hardware: Raspberry pi 3 B
      Power Supply used: Normal phone charger
      RetroPie Version Used 4.4
      Built From: 16 GB mirco SD
      USB Devices connected: AfterGlow Wired Xbox one controller, Normal Xbox controller and key bored
      Controller used:Normal Xbox controller
      Error messages received: xpad patch retropie.diff failed to apply and it wont let me config the controller
      Log found in /dev/shm/runcommand.log ):when i try to update it
      Guide used: (Mention if you followed a guide)https://retropie.org.uk/forum/topic/3200/afterglow-prismatic-wired-controller-for-xbox-one and https://github.com/paroj/xpad
      it wont recognize it as a controller on input, its a afterglow wired xbox one controller
      when i start it game and plug it in it says generic xbox controller but un configured
      • cynitalC
        cynital
        someone please help
        mediamogulM 1 Reply Last reply Reply Quote -2
          mediamogul Global Moderator @cynital
          @cynital
          As per the rules you agreed to when you signed up, please wait patiently for a reply and do not bump your posts. Have you followed the steps detailed in the setup guide? If so and it's still not working, please fill out the required information found at https://retropie.org.uk/forum/topic/3/read-this-first.
          • cynitalC
            cynital
            i installed both drivers but still not working
            • cynitalC
              cynital
              So i removed xpad, installed it again, updated it (i got the command line from git hub i dont know if its the latest version) I tried everything but the afterglow prismatic xbox controller wont still show up when i press a or anything but when i start a game and plug the controller in this shows up, look at the link https://m.imgur.com/qXjQR7G
              “generic xbox pad not configured” it knows its a controller so why doesn’t it let me do the key binds
                @cynital
                • cynitalC
                  cynital
                  RetroPie Version Used 4.4 i believe
                    @cynital said in need help getting after glow xbox one wired controller to work on retropie:
                    I thought maybe you were having multiple issues, but it appears that this is already be on the radar to be examined as early as today noted here.
                    Just a heads up; unless that power supply is rated as specifically being 5v 2.5a, you're going to run into power issues eventually.
                    • cynitalC
                      cynital
                      ok but have any idea why it wont let me config?
                        @cynital
                        I wouldn't want to speculate outside of it being related to the driver issue until it's ironed out.
                        • cynitalC
                          cynital
                          @buzz i put everything on the top of the post
                            BuZz administrators
                            Does the controller configure ok in EmulationStation initially? Can you navigate the ES menus
                            cynitalC 1 Reply Last reply Reply Quote 0
                            • cynitalC
                              cynital @BuZz
                              @buzz no after i updated every thing and use my key bored to go input the controls for the controller, it tells me to press a on the controller but it wont do anything, i cant config the key binds or anything, it says its supported so idk whats going on
                              • cynitalC
                                cynital
                                @BuZz ok so when starting the system when it loads, every thing says [ OK ] but it says [ failed ] to start load Kernel Modules. see 'systemctl status systemd-modules-load.services' foe details
                                  BuZz administrators @cynital
                                  @cynital and what's the output of that command if you type it in?
                                    mitu Global Moderator @cynital
                                    @cynital A normal phone charger is not an appropriate power source for a Raspberry PI. Please use a proper power adapter to power up your system.
                                    cynitalC BuZzB 2 Replies Last reply Reply Quote 1
                                    • cynitalC
                                      cynital @BuZz
                                      @buzz that the module failed ill take a screen shot later but do you have any idea or fix
                                      • cynitalC
                                        cynital @mitu
                                        @mitu ok whats a proper power supply?
                                          BuZz administrators @mitu
                                          @mitu Ah I didn't notice that - yeah could be power related.
                                            @cynital https://retropie.org.uk/docs/Overclocking/#power-supply & https://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md
