    need help getting after glow xbox one wired controller to work on retropie
    controller
    27 Posts 4 Posters 5.1k Views
    • cynitalC
      cynital @BuZz
      @buzz is this ok? https://www.amazon.com/Black-Mini-Portable-Charger-Built/dp/B0742NFM65/ref=mp_s_a_1_6?ie=UTF8&qid=1529881809&sr=8-6&pi=AC_SX236_SY340_QL65&keywords=pocket+juice&dpPl=1&dpID=31-lL4sd5qL&ref=plSrch im going to use it to make the pi portable so i could use it for now
      • cynitalC
        cynital @BuZz
        @buzz also if its not power related could it be something else or would you have to see the screenshot
          BuZz administrators @cynital
          @cynital That may well not be suitable. I recommend getting a proper/official PSU to rule out power issues.
          cynitalC 1 Reply Last reply Reply Quote 0
            @cynital I would prefer you to copy and paste the output rather than doing a screenshot. Please see the SSH section of the documentation. You can remotely connect to the RPI to get to a terminal to type the commands.
            • cynitalC
              cynital @BuZz
              @buzz ok ill see what i could do
              • cynitalC
                cynital @BuZz
                @buzz i found this, he had the same controller as me any other things i could do to make it work (ill try to get the error in ssh in a bit) https://retropie.org.uk/forum/topic/3200/afterglow-prismatic-wired-controller-for-xbox-one
                • cynitalC
                  cynital
                  @BuZz here is what it says https://m.imgur.com/kMKZZEZ
                  I need help fixing this (look at thr link)
