    “Failed to start load kernel modules” (SOLVED)
    errorerror on loadcontrollers
    46 Posts 2 Posters 15.5k Views
    • cynitalC
      cynital
      @mitu i found it its a bunch of stuff right?
      • cynitalC
        cynital
        @mitu https://pastebin.com/aamiR6hU i pasted it
          mitu Global Moderator @cynital
          @cynital OK, let's give it another shot. Reboot, plug in your controller and try to see if it work. Obviously, it won't work - as you reported. Exit Emulationstation, then execute the following command at the terminal
          dmesg | nc termbin.com 9999
          The command will automatically upload the log and will print an URL. Copy that URl and paste it here.
          • cynitalC
            cynital
            @mitu i got this, /http://termbin.com/a4fc with out the slash in the front tho cause it wouldent let me post with out it cause its "spam"
              @cynital From the looks of it, you're using xboxdrv - remove it and reboot. Then
              • update the RetroPie script
              • update the xpad driver from the RetroPie driver section.
              Reboot and then see if you can configure both your controllers.
              • cynitalC
                cynital
                @mitu i removed xboxdrv and rebooted then i updated retropie set up script then rebooted then updated xpad then rebooted still cant configure the xbox one afterglow wired controller, it also says in the command thing failed to start load kernel modules, the main goal is to get this controller to work
                • cynitalC
                  cynital
                  @mitu i pasted it again https://pastebin.com/DCFh33E7 also if you want me to do dmesg | nc termbin.com 9999 i can
                  • cynitalC
                    cynital
                    @mitu ok so the error is gone and it and does say failed it says active heres a updated pastebin https://pastebin.com/twN4P9Hb and this http://termbin.com/abs5 that problem is solved but the controller will not config still
                      The controller appears right now, but I don't think it's picking the correct Xbox driver (xpad) - it's not recognised as an Xbox controller.
                      [    2.738041] usb 1-1.3: New USB device found, idVendor=0e6f, idProduct=02b8
                      [    2.738079] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [    2.738091] usb 1-1.3: Product: Afterglow Wired Controller for Xbox One
                      [    2.738099] usb 1-1.3: Manufacturer: Performance Designed Products
                      [    2.738108] usb 1-1.3: SerialNumber: 000094D554F64414
                      cynitalC 1 Reply Last reply Reply Quote 0
                      • cynitalC
                        cynital
                        @mitu then what do i do?
                        • cynitalC
                          cynital @mitu
                          @mitu is there a way i could make it work? or anything
                            @cynital Give me a few minutes to see if we can pull this off.
                            • cynitalC
                              cynital @mitu
                              @mitu alright thank bro for all your time, at least we solved the "failed" issue, just let me know when you find a way or something
                                OK, since you're the only one with said controller, you have to compile a new driver version. So:
                                • exit Emulationstation
                                • open the driver's package script in an editor - run the command
                                nano /home/pi/RetroPie-Setup/scriptmodules/supplementary/xpad.sh
                                • edit line 28 and replace
                                gitPullOrClone "$md_inst" https://github.com/paroj/xpad.git
                                with
                                gitPullOrClone "$md_inst" https://github.com/cmitu/xpad.git
                                then save the file (Ctrl+o to save,confirm then exit with Ctrl+X).
                                • reinstall the xpad driver from the RetroPie-Setup script then reboot. See if the controller is detected and you can configure it.
                                After you do the steps above, you need to revert the changes you've made
                                • exit ES
                                • execute
                                  cd RetroPie-Setup
                                • then run
                                  git reset --hard
                                Report back if it worked or not.
                                • cynitalC
                                  cynital
                                  @mitu what line is 28
                                  • cynitalC
                                    cynital
                                    @mitu tu i replaced it and reinstalled xpad and rebooted still doesnt work did i have to update retropie setup script too?
                                    • cynitalC
                                      cynital
                                      @mitu did that too i went back and check if line 28 saved and it did, i uninstalled xpad then went to command made sure to save then i went to install xpad again rebooted then try to config it doesnt work
                                      • cynitalC
                                        cynital
                                        @mitu i found this if this will help https://retropie.org.uk/forum/topic/3200/afterglow-prismatic-wired-controller-for-xbox-one/3
                                        • cynitalC
                                          cynital
                                          Oh and also @mitu this is my controller https://amzn.to/2tOjFI6
                                          The problem might be that you might be looking how to do this other one https://amzn.to/2tCPfsX
                                          They are very similar but one has different firmware i think but its the same company, but ik my controller is still possible to be used on the pi I edited the 28 line like you said and did everything but still doesn’t work
                                            @cynital Post the dmesg after you updated the driver and rebooted, just to check if the gamepad is now detected as an Xbox controller.
                                            EDIT: I made some modifications, you should try to install it again as I mentioned in https://retropie.org.uk/forum/topic/18378/failed-to-start-load-kernel-modules/34 and reboot, then see if the controller gets detected. If not, execute dmesg | nc termbin.com 9999 and post the link.
