    “Failed to start load kernel modules” (SOLVED)
    errorerror on loadcontrollers
    46 Posts 2 Posters 15.5k Views
    • cynitalC
      cynital
      i am trying it again @mitu and if it doesnt work ill post the dmesg
      • cynitalC
        cynital
        @mitu it finally works!! thank you so much i revert the changes and booted it up and still works thanks!!!
          mitu Global Moderator @cynital
          @cynital OK, now what you did was install a patched version of the xpad driver, but if you update it, it will install the default driver again and you'll be in the same situation.
          I'll submit the patch to the official driver page so it would be included in the future.
          • cynitalC
            cynital
            so im going always have to do this or they are going to add it?
              @cynital Let's just give it a bit of time, the patch will probably be accepted.
              • cynitalC
                cynital
                @mitu you told them to pacth it?
