    Problems using trackball with MAME
    mame2003trackballmouse
    3 Posts 1 Posters 479 Views
      Pfredd
      I am trying to use a Kensington USB trackball with MAME2003 to play the game Major Havoc.
      If I plug in a USB mouse, the mouse works as the left-right spinner. However, if I try it with the trackball, it does not work.
      Running the game with verbose logging produces the following:
      With the USB Mouse:
      [INFO] [Video]: Graphics driver did not initialize an input driver. Attempting to pick a suitable driver.
      [INFO] [udev]: Keyboard #0 (/dev/input/event0).
      [INFO] [udev]: Mouse #0 (/dev/input/event1).
      [INFO] [udev]: Mouse #1 (/dev/input/mouse0).
      [INFO] [udev]: Plugged pad: 8Bitdo SFC30 GamePad (11720:10288) on port #0.
      [INFO] [udev]: Pad #0 (/dev/input/event3) supports 0 force feedback effects.
      [INFO] [Autoconf]: 2 profiles found.
      [INFO] [autoconf]: selected configuration: /home/pi/.config/retroarch/autoconfig/8Bitdo SFC30 GamePad.cfg
      With the Trackball:
      [ERROR] [udev] Failed to open device: /dev/input/event1 (Success).
      [INFO] [udev]: Mouse #0 (/dev/input/mouse0).
      Note the "Failed to open device"
      Any pointers on where I can look to resolve this issue?
        Pfredd
        One other point.
        If I do a cat /dev/input/event1 and roll the trackball, I do get junk rinting on the terminal screen.
        So it appears that Raspbien is able to access the device.
          Pfredd
          Switching to AdvanceMAME resolved this issue.
