    SNES emulators doesn't work
    snesdoesn´t worknotwork
    6 Posts 3 Posters 2.1k Views
      mkmonreal
      I have just installed the retropie in Debian 9 and i cannot emulate SNES games, I have tryed all the emulators and installed all differents packages.
      I hope someone can help me.
        mitu Global Moderator @mkmonreal
        @mkmonreal SNES emulator is installed automatically, you don't need to install anything if you use the RetroPie-Setup script. Have you copied any ROMs to the snes ROM folder ? Are the ROMs visible in Emulationstation after you copied them ?
        Please give more details about your system, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
          mkmonreal
          I'm running retropie 4.4.2 on Debian 9
          i've a 64 bits machine if it is useful.
          All roms are visible, but it doesn't run.
          i'm trying to install retroarch, i guess that's the problem.
          Parameters:
          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/configs/snes/retroarch.cfg "/home/miguel/RetroPie/roms/snes/Teenage Mutant Ninja Turtles IV - Turtles in Time (U) [!].zip" --appendconfig /dev/shm/retroarch.cfg
          /opt/retropie/supplementary/runcommand/runcommand.sh: line 1008: /opt/retropie/emulators/retroarch/bin/retroarch: No such file or directory
            mkmonreal
            it worked!!
              @mkmonreal So, what was the problem ? Guessing by the error above, you uninstalled RetroArch by mistake ?
                brunocrt @mitu
                @mitu I had the same issue! I also noticed somehow all the files inside the /opt/retropie/emulators/retroarch directory was missing, so I forced the updated in the core packages configuration menu inside the Retropie Setup screen. (Manage packages -> core -> retroarch -> Update from binary)
