    Overlays for different systems that use the same core; System Config file won't load (RESOLVED)
    overlayretroarch
    3 Posts 2 Posters 965 Views
    • ShizzmoneyS
      Shizzmoney
      Pi Model or other hardware: Raspberry Pi 3 Model B
      Power Supply used: Official Raspberry Pi™ Foundation 5V 2.5A Power Supply
      RetroPie Version Used: 4.2.12
      USB Devices connected: XBOX360 Controller Dongle, Keyboard, PiHut USB Hub
      Controller used: XBOX360 Controller
      emulator: lr-BlueMSX
      Thread reference:
      Re: Overlays for different systems that use the same core
      So, I am trying to setup different overlays for systems than use the same core. For example, lr-BlueMSX is used for both MSX and Colecovision.
      I have used core overrides within the Retroarch GUI for this emulator so that MSX overlay loads for all games used by lr-BlueMSX.
      I then found out the only way I do could this, per system, was to edit the retroarch.cfg in the SYSTEMNAME folder to point to where my border .cfg file lives. It was to my understanding, if I edited the system's individual retroarch.cfg file (manually or via the Advanced Config editor in Retropie via the Config Editor, example), in that folder, it would override a core's main setting.
      However, after I have done this....my Coleco border won't load, even with the retroarch.cfg in it's folder setup correctly. My file config is below:
      https://pastebin.com/QJsnbbEs
      Anyone have any ideas?
        I think RetroArch processes any overrides after the main config file, so your system settings are (obviously) overridden - https://docs.libretro.com/guides/overrides/.
        Get rid of the core overrides (for overlays) and add the overlay settings in the system's retroarch.cfg file - just like you did for Colecovision:
        • /opt/retropie/configs/msx/retroarch.cfg <- configure the overlay for MSX
        • /opt/retropie/configs/coleco/retroarch.cfg <- configure here the overlay for Colecovision.
        ShizzmoneyS 1 Reply Last reply Reply Quote 1
        • ShizzmoneyS
          Shizzmoney @mitu
          @mitu that did it, thanks!
