    Tried ES included and Steve's scraper... nothing works.
    retropie 4.4scraper neewbiescraper failedscraper imagesemultionstation
    3 Posts 2 Posters 706 Views
    • jamrom2J
      jamrom2
      Hello. I just changed over to the newest build from a pre 4.2 build. I started from scratch with a new clean 4.4 stretch image and copied over all my files/gamelists... etc.
      I'm having trouble with both scrapers not working. I get nothing. I tried the ES scraper, doesn't find anything. Tried Steven Selph's scraper, nothing. I have no other issues with downloading content, or performance of the build.
      I did not have any issues before 4.4, did I miss something while building this new image?
      Thanks in advance.
      JR
        mitu Global Moderator @jamrom2
        @jamrom2 Update your packages, since 4.4 was released there was a change in thegamesdb.net site, the source of the scraper, and you need to update. For the Steven Selph's scraper you can choose another scraping source - instead of thegamesdb - and it should work.
        • jamrom2J
          jamrom2 @mitu
          @mitu thank you. I did try changing sources with Steve's scraper, but I still get nothing.
          I'll do the upgrade and see what happens.
