    When using a usb with retropie-mount almost none of the ports show up in EmulationStation
    portsretropie-mount
    3 Posts 2 Posters 632 Views
    • V
      vleon1
      Pi Model or other hardware: B3+
      Power Supply used: I think its the official one (got it with the starters kit) STONTRONICS DSA-13PFC-05 FCA
      RetroPie Version Used: 4.4.2 (8fa87a18)
      EmulationStation version: v2.7.SRP
      RetroArch Version (I know its probably not relevant): 1.7.1
      Built From: Pre made SD Image on RetroPie website (https://github.com/RetroPie/RetroPie-Setup/releases/download/4.4/retropie-4.4-rpi2_rpi3.img.gz)
      USB Devices connected: A wireless keyboard adapter and an SP 64GB usb stick (the one with retropie-mount)
      Controller used: ps4 controller with direct bluetooth
      Error messages received: None that I know of.
      Guide used: Github pages of the relevant ports for example (https://github.com/RetroPie/RetroPie-Setup/wiki/Doom)
      Attachment of config files: I didn't do manual config file changes, and don't know what to add, please tell me and I will supply with a reply post
      How to replicate the problem:
      When I use a usb stick as my mount point with the "retropie-mount" method, everything works. But none of the intalled ports or kodi are showing up.
      When the ports folder on the usb is empty: no ports category shows up
      When the ports folder on the usb contains stuff (like the CaveStory folder, doom wads, etc..): Still no ports category
      When the ports folder on the usb contains sh scripts (like those described in the retropie doom github page): The category shows up and contains only the sh scripts, no other app (like kodi) shows up.
      When the usb is not connected: Everything installed shows up in the ports category..
      I have this port related packages installed: lr_nxengine, lr_prboom, lr_tyrquake, giana, kodi, open tyrion, sdlpop, wolf3dsdl
        mitu Global Moderator @vleon1
        @vleon1 said in When using a usb with retropie-mount almost none of the ports show up in EmulationStation:
        That means the ports have been installed on the SD card, when you didn't have the USB connected. Have you tried re-installing any of the Ports with the USB plugged in ?
        • V
          vleon1
          Thanks! that was exactly the problem!
