    Mupen64plus Update Breaks Wireless PS4 Controller Input
    dualshock 4mupen64plusmupen64plus.cfg
    3 Posts 2 Posters 1.6k Views
    • hooperreH
      hooperre
      Before I boot a ROM I try to manually change the Input name to "Wireless Controller":
      [Input-SDL-Control1]
      # Mupen64Plus SDL Input Plugin config parameter version number.  Please don't change this version number.
      version = 2
      # Controller configuration mode: 0=Fully Manual, 1=Auto with named SDL Device, 2=Fully automatic
      mode = 2
      # Specifies which joystick is bound to this controller: -1=No joystick, 0 or more= SDL Joystick number
      device = 0
      # SDL joystick name (or Keyboard)
      name = "Wireless Controller"
      # Specifies whether this controller is 'plugged in' to the simulated N64
      plugged = False
      # Specifies which type of expansion pak is in the controller: 1=None, 2=Mem pak, 5=Rumble pak
      plugin = "2"
      # If True, then mouse buttons may be used with this controller
      mouse = False
      # Scaling factor for mouse movements.  For X, Y axes.
      MouseSensitivity = "2.00,2.00"
      # The minimum absolute value of the SDL analog joystick axis to move the N64 controller axis value from 0.  For X, Y axes.
      AnalogDeadzone = "4096,4096"
      # An absolute value of the SDL joystick axis >= AnalogPeak will saturate the N64 controller axis value (at 80).  For X, Y axes. For each axis, this must be greater than the corresponding AnalogDeadzone value
      AnalogPeak = "32768,32768"
      # Digital button configuration mappings
      DPad R = "hat(0 Right)"
      DPad L = "hat(0 Left)"
      DPad D = "hat(0 Down)"
      DPad U = "hat(0 Up)"
      Start = "button(9)"
      Z Trig = "button(6)"
      B Button = "button(3)"
      A Button = "button(0)"
      C Button R = "axis(3+)"
      C Button L = "axis(3-)"
      C Button D = "axis(4+)"
      C Button U = "axis(4-)"
      R Trig = "button(5)"
      L Trig = "button(4)"
      Mempak switch = "button(11)"
      Rumblepak switch = "button(12)"
      # Analog axis configuration mappings
      X Axis = "axis(0-,0+)"
      Y Axis = "axis(1-,1+)"
      After:
      version = 2
      mode = 2
      device = 0
      name = "Wireless Controller Motion Sensors"
      plugged = True
      plugin = "2"
      mouse = False
      Start = "button(9)"
      And it proceeds to make "Wireless Controller" as player 2. I have the same input for both named controllers "Wireless Controller" is the same input config as "Wireless Controller Motion Sensors", but the latter does not function as a controller.
      4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
        spud11 @hooperre
        @hooperre I've set the mode to the following mode = 0 ie fully manual in both the Mupen64 plus config file and in the InputAutoConfig ini file.
        Perhaps try that.
        • hooperreH
          hooperre
          I found this thread that seems to contain the answer: https://retropie.org.uk/forum/topic/17650/dualshock-controllers-on-4-4-with-3b/35
