    Retroflag NESpi case + issue
    nespicasepowerissue
    3 Posts 2 Posters 917 Views
      retroisbest
      Hi there,
      I was hoping if somebody can help with a small issue I have,
      I have a genuine retroflag NESPi case plus, if the power button on the front is off and I plus the micro usb power cable in it powers on, if I then press the power button so it's now pushed in and in the on position it turns off as the shutdown script see the power button as being pressed, if I press the button back to its off position it turns on.
      Does anybody have any suggestions?
      Thanks for your help and time.
      • E
        emclinux
        Hello,
        To be honest I dont have a plus version I have the original without the safe shutdown. So im going to assume that you have checked all the wiring and its good to go. If your running a rpi3+ you may want to look at this: https://retropie.org.uk/forum/topic/19248/retroflag-snes-case
        Chances are that even though its talking about the snes case its the same internals. In that thread (https://retropie.org.uk/forum/topic/19248/retroflag-snes-case/22) cyperghost recommeds setting the enable_uart=0 in config.txt
          retroisbest @emclinux
          @emclinux thankyou I will give that a try tonight
