    Msx roms not working after i changed bios machine
    msx bios
    8 Posts 3 Posters 610 Views
      thepianist80
      I have alot of msx roms working in my raspberry pi 3 , but when i enter retroarch menu inside one of the game i changed the bios machine by mistake , so now the msx roms not working it gives me black screen and restart to main menu and i can't enter the retroarch menu (inside the games) to change back the bios , so what can i do to change back the setting to make the roms working again ,,,,,, HELP PLEASE , i am new here , and not experience for retropie
        Please add the information from https://retropie.org.uk/forum/topic/3/read-this-first - which release/RA version are you using ?
          edmaul69 @thepianist80
          @thepianist80 try playing an msx 1 game. Then change the bios back.
            thepianist80 @edmaul69
            @edmaul69 i can't change it , because retroarch menu will not work if the game not working (it gives black screen and return to main menu )
              @thepianist80 most bios’ you set should work and boot the game if it is an msx 1 rom and not msx 2 or msx2+ roms. Otherwise open up the file /opt/retropie/configs/all/retroarch-core-options.cfg and fix the bios section for the msx emulator you are using.
              T 2 Replies Last reply Reply Quote 0
                @edmaul69 sorry i don't know how to do it , can you tell me the steps please , and thank you very much
                  @edmaul69 can you please tell me how i open that file , if you tell me the steps i will be very thankful for you
                    @thepianist80 go to commandline and type:
                    sudo nano /opt/retropie/configs/all/retroarch-core-options.cfg
                    look for the line:
                    bluemsx_msxtype =
                    and change whatever it is set as to:
                    bluemsx_msxtype = "MSX2+"
                    caps are important.
