    100% noob trying to be a geek, begging for help with Roms. Please......
    roms
    132 Posts 11 Posters 30.3k Views
    • V
      VictimRLSH
      Each ROM the emulator is capable of running has its own internal configuration that is tied to the name of the ROM .zip file. It MUST have the correct filename, and also must not be unzipped.
      Your best bet is to run the ROMS through CLRMamePro with the 0.78 dataset and it will figure out how to create the proper .zip file with the ROM data you actually have. There is a tutorial video for CLRMamePro in the MAME FAQ page pinned in the gaming discussion forum HERE https://retropie.org.uk/forum/topic/2859/how-to-use-mame-with-retropie-help-guide/30
      One thing that guide doesn't mention is BACK UP YOUR ROMS before letting CLRMamePro loose on them, if you choose the wrong options it can easily corrupt or erase your original ROM data.
      System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
        dankcushions Global Moderator @VictimRLSH
        honestly i would advise against going down the clrmamepro route at this point. just redownload the full romset if you haven't kept a copy.
        just do the absolute basics. put the full 0.78 romset in the mame-libretro folder, and set the default emulator to lr-mame2003. that's essentially all you need to do.
        V U 2 Replies Last reply Reply Quote 1
        • V
          VictimRLSH @dankcushions
          @dankcushions True, not the best option for a noob now that I think about it. My ROMS were from a massive virutally every rom in existence torrent that was a complete cluster$%&* and absolutely needed sorthing out with CLRMamePro.
          • U
            ucald4amarine @dankcushions
            @dankcushions
            Sheesh... The more I learn from you all, the more of an idiot I feel... Thanks for all of your time and patience with me. I know this is hard to believe, but I am learning from my mistakes.
            • U
              ucald4amarine @rbaker
              @rbaker you suggested putting the game files in the arcade section. As far as I'm currently understanding this, it seems to me that the arcade section may be the best place to put everything, as it gives me all the emulations needed. Could you explain please why I would(or should) use the rest of them? (Mame, neo-geo, etc. Perhaps for game specific platforms such as snes?)
              • V
                VictimRLSH
                If you want all the 'good' stuff in one place, mark it as a Favorite, and it will show up in your Favorites list regardless of the platform. Putting everything in one directory is going to create a navigational nightmare.
                • U
                  ucald4amarine @VictimRLSH
                  @VictimRLSH
                  I was only planning on putting about 50 games on the Pi, as growing up, my brothers and I didn't have much access to games or computers of any kind until about 2008, when we moved out of our families farm. So, really, there are a very small number of games that we had ever played when we snuck out to the movies or something. Given that it's a small list, would leaving it all in arcade be wise, or should I still plan to sort out which one goes in which?
                  • V
                    VictimRLSH @ucald4amarine
                    @ucald4amarine The console games need to be in their respective directories for the emulators to find them, but you CAN put all your MAME games in the Arcade directory. If you have console or computer games as well, you'll need to use the Favorites to get everything in one place anyway.
                      Clyde @ucald4amarine
                      @ucald4amarine said in 100% noob trying to be a geek, begging for help with Roms. Please......:
                      Everything arcade, as @VictimRLSH already explained. I just wanted to strengthen that information.
                      One scenario would be that you have games in multiple versions for different emulators. You could put the mame2003 versions in one directory and the mame2010 versions (edit)of the same games(/edit) in another. You'd have multiple MAME systems in Emulation station that way.
                      I keep the Neo Geo ROMs I bought from gog.com separate from the rest of my arcade ROMs this way.
                      • U
                        ucald4amarine
                        Copy all. That's good to know then. Doesn't necessarily simplify my task, but it will be a good learning experience for me. (Which this whole thing has been) I'll have to put up a pic of the finished cabinet. Show that I do have some talents here.
                        • U
                          ucald4amarine @Clyde
                          @Clyde just pulled up gog.com and was browsing, are these files the same as room files downloaded or would I need a different emulator installed on the retropi software?
                            @ucald4amarine Look at this post from me how to extract the roms from the GOG installer files. There also is a link to the ROMs on gog.com. All of them work on my RetroPie 4.4 with the standard emulator for the roms/neogeo directory, lr-fbalpha. (edit: As far as I tested them, but at least as far as some minutes into the game.)
                            You may also want to look at the opening post of that thread, where @BenMcLean has collected many legal sources for various ROMs.
                            • U
                              ucald4amarine
                              Im back! And... Once again, I have been running searches and attempting to fix on my own. But... Once again, Im stumped...
                              Ive built one cabinet. And it doesnt look half bad. Some things to improve on the next build, but its not all that bad. The software though... There is a issue with the sound, (I still have to go into the boot menu and delete the # sign and Get it to go through the headphone jack. So I think I may have the solution worked out on that.) But even though Ive gone through the retroarch section for setting up the 2nd set of controls, it hasnt fully worked out. Ill explain.
                              I go through the retroarch control settings, go to the 2nd player controls, and everything appears to automatically copy itself correctly. I am not able to make any changes to the controls anyways. But when I go In game to test, I find that the emulator now just takes imputs for both players through the player one controls, and only responds to a couple of imputs from the 2nd player. This is something that I havent been able to find a similar issue with through the forums at all.
                              And 2ndly, whenever I boot up a fresh copy of retropie, everything seems to work great. (Excepting sound and the 2nd set of controls. ) But the moment I go into settings and try to set sound to anything different from stock, I lose all control in game. Outside in menu still great. But in game, I cant do anything at all...
                              Again, I thank you all for your time and efforts.
                                i think for the most part, you shouldn't be going into the retroarch options and changing things at all. one of the major points of retropie is to automate all that stuff for you. if you start changing things, you're now likely overriding what retropie does for you, and this can have unintended consequences. you won't find many parts of our documentation that instructs you to start digging around retroarch and changing things.
                                if you have a second controller, you just add it within emulationstation just like you did for player 1. if it's the same controller model as player 1, you won't even have to do that - it will just work.
                                with the sound settings, what are you trying to change? what problem are you trying to solve in the menu?
                                  mitu Global Moderator @ucald4amarine
                                  @ucald4amarine Please add more details about what type of controller have you added to your build.
                                    Pepper @ucald4amarine
                                    This post is deleted!
                                      mitu Global Moderator @Pepper
                                      @Pepper We've been through this already - have a look at the rest of the topic :).
                                      • U
                                        ucald4amarine @mitu
                                        @mitu Sorry about that. i should have included it. Its a twin stick setup. Here is a link to the amazon site: EG Starts 2 Player Classic Arcade Contest DIY Kits USB Encoder To PC Joystick + 8 Ways Sticker + Chrome Plating LED Illuminated Push Button 1 & 2 Player Coin Buttons For Arcade Mame Raspberry Pi Games https://www.amazon.com/dp/B06WGX76HT/ref=cm_sw_r_em_apa_1sc.BbCDKBS4X
                                        Dankcushions, To answer your question, Im following the instructions for the 2nd controller through this page here: https://retropie.org.uk/docs/RetroArch-Configuration/ and thats where Im getting the retroarch lead. And like you said, it seems to match up with the first set of controls perfectly. But im not able to change it or make any adjustment to it to test it out. And finally, Im trying to run a couple cheap speakers with their own power supply through a headset jack plug via the PIE3 port. I know the speakers work. What I was trying to do in menu was simply set it to headphone vs every other option. Which then lead to none of the controls working in game.
                                          From the descriptions, it looks like each controller has it's own USB cable, so they should be seen as separate gamepads.
                                          As @dankcushions said, you shouldn't need to go into the RetroArch to configure the controller, if you have configured in Emulationstation the 1st controller, it should automatically configure the 2nd one. I assume they'll appear identical to RetroPie, so the same configuration would apply to both. This also means you'll have to wire the buttons identically - i.e. using the same schema to connect them to the encoders.
                                          • U
                                            ucald4amarine @mitu
                                            @mitu your correct. It does have its own usb port. But I cannot use the emulation station to make any movement or button controls on the 2nd gamepad. But, if I'm reading you correctly, I will need to rewire the 2nd controller to be a mirror image of the 1st controller, vs plugging it in haphazard style.
