    Could not successfully build lr-caprice32 - Amstrad CPC emu
    install errorcaprice
    11 Posts 3 Posters 1.4k Views
    • DannoD
      Danno
      Retropie installation with a freshly-installed Linux Mint 19.1 computer is failing with the error in the subject line. I've tried for several days now, to try and rule out a temporary issue with the lr-caprice32 GIT server, but the error continues. Most of the preceding steps in the installation script are successful, but no menu shortcut for RPIE is created.
      A few months ago, I ran the installation on a Linux Mint 18.3 computer without any issue. I'll attach the entire log file if I can determine how to do that in this forum, but here are some of the lines preceding the failure:
      libretro/retro_strings.c:72:7: warning: implicit declaration of function ‘strncasecmp’; did you mean ‘strncmp’? [-Wimplicit-function-declaration]
         if(!strncasecmp(str, start, strlen(start)))
             strncmp
      libretro/retro_strings.c: In function ‘strendswith’:
      libretro/retro_strings.c:82:7: warning: implicit declaration of function ‘strcasecmp’; did you mean ‘strncmp’? [-Wimplicit-function-declaration]
         if(!strcasecmp((char*)&str[strlen(str)-strlen(end)], end))
             strncmp
      cc -c -o libretro/retro_files.o libretro/retro_files.c -O2 -march=native -pipe -std=c99 -O3 -DLOG_PERFORMANCE -DGIT_VERSION=\"" 0bbf84a"\" -fPIC -D__LIBRETRO__  -DINLINE="inline" -DHAVE_CONFIG_H -Wall  -I. -I./cap32 -I./cap32/libcpccat -I./libretro -I./libretro/nukleargui -I./libretro/nukleargui/nuklear -I./libretro/nukleargui/retro
      libretro/retro_files.c: In function ‘file_exists’:
      libretro/retro_files.c:30:59: error: ‘S_IFDIR’ undeclared (first use in this function); did you mean ‘S_ISDIR’?
            (buf.st_mode & (S_IRUSR|S_IWUSR)) && !(buf.st_mode & S_IFDIR))
        S_ISDIR
      libretro/retro_files.c:30:59: note: each undeclared identifier is reported only once for each function it appears in
      Makefile:328: recipe for target 'libretro/retro_files.o' failed
      make: *** [libretro/retro_files.o] Error 1
      make: *** Waiting for unfinished jobs....
      ~/RetroPie-Setup
      Could not successfully build lr-caprice32 - Amstrad CPC emu - Caprice32 port for libretro (/home/dan/RetroPie-Setup/tmp/build/lr-caprice32/cap32_libretro.so not found).
      ~/RetroPie-Setup/tmp/build/lr-fbalpha ~/RetroPie-Setup
        The problem seems to be upstream, there have been some recent commit recently that added this error - there's nothing wrong with your installation.
        • DannoD
          Danno
          That's a little comforting to hear. So, am I stuck waiting for a fix to be committed upstream before I can try again? I don't have any games on the Amstrad platform, but I can't seem to get the RPIE shortcut to be created with the error occurring.
            mitu Global Moderator @Danno
            @Danno I don't think this has anything to do with it. The desktop shortcut is added by the Emulationstation package installation - did you get any errors when installing that package ?
            DannoD 1 Reply Last reply Reply Quote 0
            • DannoD
              Danno @mitu
              @mitu Well, the only error listed explicitly at the end of the script execution was the one involving Amstrad. I scanned through the entire log, searching on "EmulationStation", but don't see anything concerning:
              Installing dependencies for 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
              ~/RetroPie-Setup/tmp/build/emulationstation ~/RetroPie-Setup
              Getting sources for 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
              git clone --recursive --depth 1 --branch stable "https://github.com/RetroPie/EmulationStation" "/home/dan/RetroPie-Setup/tmp/build/emulationstation"
              Cloning into '/home/dan/RetroPie-Setup/tmp/build/emulationstation'...
              Cloning into '/home/dan/RetroPie-Setup/tmp/build/emulationstation/external/pugixml'...
              Building 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
              -- Build files have been written to: /home/dan/RetroPie-Setup/tmp/build/emulationstation
              /home/dan/RetroPie-Setup/tmp/build/emulationstation/es-core/src/components/VideoVlcComponent.cpp: In member function ‘virtual void VideoVlcComponent::startVideo()’:
              /home/dan/RetroPie-Setup/tmp/build/emulationstation/es-core/src/components/VideoVlcComponent.cpp:298:30: warning: ‘void libvlc_media_parse(libvlc_media_t*)’ is deprecated [-Wdeprecated-declarations]
                               from /home/dan/RetroPie-Setup/tmp/build/emulationstation/es-core/src/components/VideoVlcComponent.cpp:7:
              Scanning dependencies of target emulationstation
              [ 73%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/FileData.cpp.o
              [ 73%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/FileSorts.cpp.o
              [ 73%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/MameNameMap.cpp.o
              [ 74%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/main.cpp.o
              [ 75%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/MetaData.cpp.o
              [ 76%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/PlatformId.cpp.o
              [ 76%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/ScraperCmdLine.cpp.o
              [ 77%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/SystemData.cpp.o
              [ 78%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/VolumeControl.cpp.o
              [ 78%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/Gamelist.cpp.o
              [ 79%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/FileFilterIndex.cpp.o
              [ 80%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/SystemScreenSaver.cpp.o
              [ 80%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/CollectionSystemManager.cpp.o
              [ 81%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/components/AsyncReqComponent.cpp.o
              [ 82%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/components/RatingComponent.cpp.o
              [ 82%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/components/ScraperSearchComponent.cpp.o
              [ 83%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiFastSelect.cpp.o
              [ 84%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiMetaDataEd.cpp.o
              [ 84%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiGameScraper.cpp.o
              [ 85%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiGamelistOptions.cpp.o
              [ 86%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiScreensaverOptions.cpp.o
              [ 86%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiGeneralScreensaverOptions.cpp.o
              [ 87%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiVideoScreensaverOptions.cpp.o
              [ 88%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiSlideshowScreensaverOptions.cpp.o
              [ 88%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiMenu.cpp.o
              [ 89%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiSettings.cpp.o
              [ 90%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiScraperMulti.cpp.o
              [ 90%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiScraperStart.cpp.o
              [ 91%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiGamelistFilter.cpp.o
              [ 92%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiCollectionSystemsOptions.cpp.o
              [ 92%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/guis/GuiInfoPopup.cpp.o
              [ 93%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/scrapers/Scraper.cpp.o
              [ 94%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/scrapers/GamesDBScraper.cpp.o
              [ 94%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/BasicGameListView.cpp.o
              [ 95%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/DetailedGameListView.cpp.o
              [ 96%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/IGameListView.cpp.o
              [ 96%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/ISimpleGameListView.cpp.o
              [ 97%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/GridGameListView.cpp.o
              [ 98%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/gamelist/VideoGameListView.cpp.o
              [ 98%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/SystemView.cpp.o
              [ 99%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/ViewController.cpp.o
              [100%] Building CXX object es-app/CMakeFiles/emulationstation.dir/src/views/UIModeController.cpp.o
              [100%] Linking CXX executable ../emulationstation
              [100%] Built target emulationstation
              Installing 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/CREDITS.md' -> '/opt/retropie/supplementary/emulationstation/CREDITS.md'
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/emulationstation' -> '/opt/retropie/supplementary/emulationstation/emulationstation'
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/emulationstation.sh' -> '/opt/retropie/supplementary/emulationstation/emulationstation.sh'
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/GAMELISTS.md' -> '/opt/retropie/supplementary/emulationstation/GAMELISTS.md'
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/README.md' -> '/opt/retropie/supplementary/emulationstation/README.md'
              '/home/dan/RetroPie-Setup/tmp/build/emulationstation/THEMES.md' -> '/opt/retropie/supplementary/emulationstation/THEMES.md'
              /opt/retropie/supplementary/emulationstation ~/RetroPie-Setup
              Configuring 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
              Running action 'install_theme' for 'esthemes' : Install themes for Emulation Station
              Installing dependencies for 'retropiemenu' : RetroPie configuration menu for EmulationStation
              Installing 'retropiemenu' : RetroPie configuration menu for EmulationStation
              Configuring 'retropiemenu' : RetroPie configuration menu for EmulationStation
              My assumption was that the logic in the script which adds the "RPIE" entry in the menu didn't get a chance to run when the script aborted due to the Amstrad error. Is that not correct?
                Emulationstation seems to have been installed without error, the desktop icon should have being installed - have you search for retropie in the list of applications ? You can run emulationstation from the terminal and see if it gets started.
                • DannoD
                  Danno
                  EmulationStation did successfully launch from the command line. As a mini test, I copied over one (Nintendo 64) ROM and the game did launch successfully and gameplay seemed solid. However, when I went to re-scrape game information (from TheGamesDB), it failed with "No Games Found" each time. I don't want to veer off onto a different issue from the primary one I posted, but I never encountered a problem with the scrape function on my other (Mint 18) setup.
                  Is this unrelated to the setup script failure, do you think? Also, is there a non-manual way to add the normal entry in the Mint menu (category of "Games" was added, with an entry for "RPIE" with the proper icon)?
                  • DannoD
                    Danno
                    Mea Culpa on the missing menu entry - when I went to manually add an entry, I saw that the entry was already showing in the Menu editor. I then remembered that I had to reboot (log off / on again might have sufficed) in order for the new menu entry to appear for rpie.
                    But, I added a few more games (MAME ROMs this time), and I still can't get any of them to scrape successfully. So, my questions now are these:
                    1. Should I open a new issue for the Caprice32 bug at it's GitHub site (https://github.com/libretro/libretro-cap32)?
                    2. Should I start a new forum thread for the scraping issue? I haven't had a chance to search much yet on that one, but am wondering in case I don't find an existing issue reported already.
                    • DannoD
                      Danno
                      Sheesh...another Mea Culpa due from me. I see the somewhat-recent post you made for the scraping problem: https://retropie.org.uk/forum/topic/20613/emulationstation-internal-scraper-problems/2
                      I include it here in case it helps someone else landing in this thread.
                        BuZz administrators
                        please try updating retropie-setup and rebuilding lr-caprice32 again.
                        • DannoD
                          Danno
                          Pulled latest Retropie-Setup from git, reran, and this time there were no errors showing afterward (i.e. the main menu for the script was showing as expected). I looked through the log file, especially the section involving lr-caprice32, and didn't see any fatal errors (just some compile warnings).
                          Thanks for the follow up.
