    portable project questions about wii nunchuck
    wiinunchuckgpioretropiearcade
    2 Posts 1 Posters 401 Views
      krullbeast
      hello,
      I'm building a portable Pi3b project on the newest retropie utilizing Raspbian. Is it possible to use the wii nunchuck (joystick with c and z buttons) AND two arcade microswitches? can i use 12c AND gpio at the same time?
      thank you very much!
        krullbeast
        @krullbeast more specifically, can i map the nunchuck(as a directional pad also) C and Z buttons as select and start in emulation station or retroarch AND also have two seperate A and B buttons wired to GPIO pins on my Pi 3b? will they all communicate with the Pi? or will the A and B buttons not work after enabling 12c serial at start up?
        i am very new to this, please forgive me if i sound stupid.
        and thank you for any advice
        this is a rough schematic of what i'm trying to build
