Help! Led buttons turning on after shuting down my pi
  • Arcade1up ETA mod have a question maybe you can help my pi damage 3 microsd cards so i opted to boot from usb everything works great only thing is 10 sec after i turn off the pi al the buttons light up again even though my pi shut down any thoughts on this?
    btw im using the 32GB Arcade Only image by Wolfanoz didnt do that when it boot from microsd card
    shutting down system the tradicional way pressing player 1 aka start then quit then shutdown system
    Pi Model 3B+
    2.5A Power Supply
    SanDisk 32GB Cruzer Fit USB Flash Drive with boot image
  • If I were to hazard a guess, I would say that changing over to a USB boot means that your USB ports are staying powered on when your system isn't running. You should probably just unplug the power source after shutdown.
