    Screen Rotation per Rom Help
    screen rotationconfig
    9 Posts 3 Posters 976 Views
    • t_mitchT
      t_mitch
      I've got my screen rotated vertically by editing the boot/config.txt file. But I have one or two games that need to be horizontal.
      I've seen a few threads online that talk about setting up the config for each rom, but they all seem to assume some knowledge I don't have.
      Where do I find the config file for an individual rom? What exactly do I need to put in it rotate the screen?
      Thanks.
        mitu Global Moderator @t_mitch
        @trey_mitchell You create a .cfg file for the ROM - with the ROM name - alongside the ROM file - https://retropie.org.uk/docs/RetroArch-Configuration/#config-hierarchy.
        To rotate the display, add
        video_allow_rotate=true
        video_rotation =  X
        where X = 1, 2, 3 = 90, 180, 270 - see https://retropie.org.uk/forum/topic/12539/.
        You can also use the RGUI (RetroArch interface) to change the video orientation, then save a game override so you don't have to manually create a .cfg file.
        t_mitchT 1 Reply Last reply Reply Quote 0
        • t_mitchT
          t_mitch @mitu
          @mitu said in Screen Rotation per Rom Help:
          video_rotation =  X
          I tried the .cfg file. It goes in the same directory as the rom? If so, that didn't work.
          How do I access RetroArch? I've seen several different button combos listed online, but none seem to do anything.
            @t_mitch said in Screen Rotation per Rom Help:
            The combination is Hotkey + X, where Hotkey is the button you chose as Hotkey for your gamepad during configuration in Emulationstation. Usually it's Select + X.
            • t_mitchT
              t_mitch @mitu
              No dice. Holding hotkey and x doesn't do anything. Maybe I should start another thread about that?
              Could these two issues (not being able to bring up Retroarch and the .cfg files not working) be related?
                dankcushions Global Moderator
                what emulator? not all emulators are libretro (retroarch)
                • t_mitchT
                  t_mitch @dankcushions
                  @dankcushions said in Screen Rotation per Rom Help:
                  MAME w/ MAME4All
                  • t_mitchT
                    t_mitch
                    OK, I switched to LR-MAME2000 and now I can get into Retroarch and after A LOT of hunting and pecking found the setting for screen rotation.
                    Thanks!
                      @t_mitch Mame4All is not a Libretro emulator, so the hotkey combination don't apply (and also the .cfg file has no effect). But you found the solution, so that's good.
