    Waveshare GameHat + Retropie + 3A+ GamePad doesn't work
    gamehatwaveshareretropiegamepad
    1 Posts 1 Posters 725 Views
    • Z
      zuendy
      Hi,
      sorry for my bad english.
      I have a Waveshare GameHat (https://www.waveshare.com/game-hat.htm). It works great with Rasp PI Zero and Rasp Pi 3b with driver set from waveshare. But i want to work with PI 3A+
      I installed Raspbian + Retropie and it works with an USB Gamepad.
      But I would prefere the gamepad from Waveshare ;) , it's GPIO based with no standard Pinout.
      So I installed the mk_arcade_joystick_rpi via
      sudo /home/pi/RetroPie-Setup/retropie_setup.sh
      under driver
      Than I used this manual https://github.com/recalbox/mk_arcade_joystick_rpi
      At first remapping:
      sudo modprobe mk_arcade_joystick_rpi map=4 gpio=5,6,13,19,21,4,26,12,23,20,16,18, -1
      Pins should be correct, later I found this pinout in another manual for recalbox here: https://www.instructables.com/id/Setup-Waveshare-Game-Hat-for-Recalbox-and-Kodi/
      than Autoload for startup
      sudo nano /etc/modules
      insert: mk_arcade_joystick_rpi
      sudo nano /etc/modprobe.d/mk_arcade_joystick.conf
      insert: options mk_arcade_joystick_rpi map=4
      command for testing inputs doesn't work, found no jstest
      jstest /dev/input/js0
      After reboot said emustation, gamepad ist detected, but the buttons have no function. :(
      Can somebody help me and said what I made wrong?
      Thx for reading.
      zuendy
