    can udev read i2c and hardwired GPIO buttons simultaneously?
    wiii2cretropie 4.4retroarchjoypad config
    4 Posts 2 Posters 767 Views
      krullbeast
      I'm trying to create a joypad similar to a classic nes controller to work in retroarch. I want to use a wii nunchuck for the joystick and select and start buttons and also have two buttons hardwired to the raspberry pi 3b running retropie 4.4
      i finally got the nunchuk to send other data than 255, it seemingly is working including the c and z buttons. my A and B buttons are wired to specific GPIOs.
      Is it possible to create a joypad from this setup to be able to play games in retropie? or is it not possible?
      thank you for any advice!
        mitu Global Moderator @krullbeast
        @krullbeast You can try to see if any of the GPIO based modules for joypads works for your setup - https://retropie.org.uk/docs/GPIO-Modules/. But if you only have the A/B buttons wired to the GPIO it might now work - insufficient buttons.
        Othwise, you'll need to create your own virtual keyboard - similar to how https://github.com/adafruit/Adafruit-Retrogame works.
          krullbeast @mitu
          @mitu thank you!
          i'll try the gamecon advice and see what happens. do you think it is possible to read the i2c data and also the A and B buttons inside of retroarch?
            @krullbeast said in can udev read i2c and hardwired GPIO buttons simultaneously?:
            Not an expert on this, but I think RetroArch doesn't read directly from GPIO (I2C or otherwise), instead it uses an established input driver (udev/sdl/etc.) - https://github.com/libretro/RetroArch/tree/master/input/drivers.
